Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Hi, my remote control mute and power button do not function. Is there a trouble shooting solution, or do i need to buy another remote? I own a Viewsonic N2752w 27'' widescreen LCD TV
  • 767 Answers
Yes , point it at your digital camera or video camera and
in the viewer you should see the remote blinking a blush white
light when you press any button . sound like the pads are
dirty ,and need to be opened and cleaned.
Posted on Jun 30, 2009
SAMSUNG TV MUTING IT SELF
Hi, you may are having problems with your Remote Controller, try this for the fowlling order:
1?- remove the bateries from the remote controller
2?- turn on the tv with the power button on the tv
3?- wait a little bit, to see if it is mutting itself
4?- if not, your problem may be with the bateries, try new ones
5?- if the tv still mute itself you have a faulty remote controller, buy another one
Oct 16, 2013 | Samsung TV CS29Z40
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
http://www.thompsontv.com/rcarc.html
click the above link and programmed your remote control..
thanks
good luck
Oct 01, 2008 | Sony SLV-679HF VHS VCR
Cobolt 3 in 1 jumbo remote control
have u checked wether is is supported or not????
it may not be supported.............
Sep 18, 2008 | Televison & Video
No sound is coming out
Look for a button on the unit or remote for turning speakers on end off, Or when you go into the unit menu, Watch with the functions if it stays something about the speakers, Turnig them on or off, If you don,t come across any of this stuff, Get a manual for it, End see if you can find any thing about it in the manual, In the trouble shooting (Section) If you don,t have a manual for it, Try manuals online.com
Dec 06, 2012 | Emerson AV301 System
I pushed a button and lost all sound, what should i do? is there a reset button to get going again?
The "MUTE" function on your remote control has been activated.To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office.
Dec 16, 2010 | Yamaha HTR-5930 Receiver
I can hear but people can't hear me
Try to unmute the headset. This may be your problem. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
Aug 27, 2010 | Motorola Mobility H710 Bluetooth Headset
My I use my H 710 I can hear my customers but they can not hear me. How do I remove mute? Thanks
Aug 23, 2010 | Motorola Mobility H710 Bluetooth Headset
I can hear the other person but they can't hear me
Your headset may be muted. Try to unmute the call. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
Aug 18, 2010 | Motorola Mobility H710 Bluetooth Headset
Certain buttons wont respond
I had a Sony remote that got dropped. Looked inside and found the circuit board broken. The ideal solution is to by a direct replacement--expensive. I had an amplifier remote with learning and lots of buttons. The cheapest ($10-$15) is to buy a universal remote, hopefully with a learning function in case you need to get more that just the numbers, volume, mute, and up/down. They may not know how to change source, TV/VCR, menu, etc. Most will know how to do Sony while many will not know off brands. -Ken
Aug 29, 2009 | Sony RM-Y173 Remote Control
I have a philips universal cl035a remote.i need the codes for panasonic tv.
In the manual it say's that what you need to do is hold the code search button untill it stay's steady then press the function button (TV, cable or whatever) for the device you need to program before doing this though turn the TV or whatever on first. Then go to the chanel select up or + button and continue to press it until it changes channel if you over shoot it you can press the - or channel down button.
When you are were you want to be quickly press the mute button and release ( warning do not hold the mute button just press it quickly and release.) This will set the remote to the corect code.
May 11, 2009 | RCA Universal Remote Control
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
192 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
