Question about Vizio L37 Television
I have a Sharp Aquos that has bright green areas where the black/dark areas should be. This starts after having the TV on for only a short period of time. Also when this occurs, the picture becomes grainy. Why?
  • 1pinkdrink Jun 17, 2009
    Any other suggestions?
    Scholar:
  • 106 Answers
Unfortunately, but the problem is related, as it is possibly your console's GPU (Graphic Processing Unit) is failing and will need to replaced, sorry to say u but this is causing u those green areas in ur television...
u can contact sharp aquos by visiting the follwing link
http://www.sharpusa.com/products/support/glossary/0,2322,,00.html
thank u
rate me
Posted on Jun 17, 2009
  • 2,071 Answers
ONE: First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.In order to dissipetate the remaining current stored in the memory.
TWO: If the reset does not help, try disconnecting anything on input 2. For example, if you have a dvd player connected to that input, the tv may be sensing its presence and switch over to it. (Especially, if the device is left ON.)
THREE: It is possible the controller IC is defective and is wandering around (electronically speaking). In this case, the set would need to be seen by a tech who can get inside and test the circuitry that controls the function switching. Lugging a big set like this into a shop is not easy, but is will save you lots of money compared to having them come to your home.
Let me know if you need more....
Hope this may help;
Regards,
VOTIT
Green screen upon shutting down or green color replacing black .. Fuzzy green on some dark scenes.. Sharp Aquos LCD TV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 29, 2015 | Sharp Televison & Video
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Green lines in black areas
sorry to say your LCD panel is failing they are expensive , i hope your under warranty
Nov 23, 2009 | Televison & Video
Flicker
I have the same problem when going to dark scenes from a bright scene or during channel changes. Sharp sent a tech under warranty and he installed new software to no avail. He called sharp tech support and they suggested turning on opc. The TV works fine but you must adjust sharpness and contrast to achieve an acceptable picture. I paid $868.00 for the set a Sam's club and will buy an extended warranty. I will not buy another sharp. My 40" sony works perfectly.
Oct 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green vertical lines
Possibly needs a new control circuit board or lcd panel
Jun 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos
Shine a bright light on the screen, do you see the image (but very very very dark)? If so, its either a bad inverter or lamps, which are only sold with the LCD panel as an assembly, which is very expensive (more than the TV is worth).
Mar 09, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Brightness control
i have a 46" aquos and i had this problem on the first day i called and everything! but everyone said just to return and exchange but im pretty sure i will ge the same result i played around and i turned OPC "on" and it stopped flickering and stays stable butttt its really dark during night scenes. i love this tv so even though the night scenes are garbage im keepin it!
Aug 18, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vizio L37 Television Logo
74 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
