Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I am installing a throttle pusher and choke arm in a Husvarnia Rancher 55 Chainsaw. I need a diagram to help me install throttle arm. Do you have a picture or diagram of the Fuel components for a rancher 55?
    President:
  • 2,220 Answers
Try downloadinf the IPL here:
http://www.husqvarna.com/us/homeowner/support/download-manuals/
I should help.
Lou
Posted on Sep 04, 2009
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Need assembly instructions for 455 Rancher throttle installation
Gently ease back the blue plastic clip ( c ) the rod will lift out of the carb, pull it to the right and then forward away from the tankand out.adw1_13.jpg
Sep 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Started 455 rancher after setting for about a month. always used stabil in fuel. started with choke on and then turned off choke once saw was running. the saw seemed to be stuck in high idle and would take...
This sounds like the throttle spindle sticking, or the cable sticking, if you remove the top cover and air filter, then push the throttle spindlefully back to the stop screw with your finger, then try again, the spindle may be a little gummed up.
Mar 18, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 09 455 rancher that will start with choke on . Idles with choke off but bogs when throttled up. I believe the bottom carb gasket is leaking. Parts houses say call for carb parts.
If gas is leaking from the carb, can you see if it is a damaged fuel line with a leak or coming from the carb itself. If it is the carb tighten the screws on the carb itself. If neither one is the problem you probably do need a carb kit installed. Hope this is helpful. Best regards and good luck.
Jan 08, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 455 rancher that won't run at full throttle unless the choke is on. It runs at half throttle fine.
Clean or replace the fuel filter. Check the fuel lines for decay or other damage. Check the muffler for plugging of the screen. Be sure to run with fresh fuel mix and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Nov 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Installing throttle cable on Husqvarna 445 chainsaw
Try blocking the throttle arm on the carburetor in the wide-open position with a small stick, then deal with the trigger mechanism. In order to remove the cable from the carburetor, you need to remove the carburetor itself, then unhook the cable end at the throttle arm. Keep track of which fuel hose goes where if you do this. Hope this helps!
Mar 31, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a rancher 55 and I had to reconnect the gas line to the carburator and now I can't reconnect the throttle I need a view of the throttle assembley. Where can I find one thank you
55 IPLs start at page 4 but I doubt it has the level of detail you need.
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I suggest you go here and join.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
The following thread is about your saw. Someone of will probably be willing to provide the photo you need. There are other threads where your saw is discussed.
http://www.arboristsite.com/showthread.php?t=122545&highlight=55+rancher
I must warn you. Many that frequent here develop an obsession with chainsaws. When I joined I had 1 and had only owned 2. I now own 7 and am always on the look out for a new one.
Good luck with your project. HTH
Lou
Feb 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
464 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
