Question about Whirlpool RF378LXKS Electric Kitchen Range
Oven Door will not close properly
I believe the springs on my oven door have weakened to the point where the door cannot close completely. The oven light does not go off. Is the solution replacement of the spring?
Re: Oven Door will not close properly
Cleaning lady knocked the hinge springs off my oven door, so i'm
trying to figure out how to reattach them.
On My GE44 stove, there is an adjustment for the spring, where it attaches at the bottom (inside the stove), there are several holes the spring can be attached to. (I found his described in a little "Pub. No. 31-0773/SR4034 paper in an envelope taped to the back of the stove)
Doing this while the stove is installed may be a challenge though,
(that's basically the problem i'm having) it would be easy if the stove was upside down.
Posted on Jan 14, 2008
    Problem Solver:
  • 19 Answers
Re: Oven Door will not close properly - Whirlpool RF378LXKS Electric Kitchen Range Kitchen Ranges
Complete door hinge needs to be replaced
Posted on Nov 01, 2007
Posted on Feb 08, 2009
SOURCE: Oven Door will not close properly
i havent got a clue
Posted on Mar 09, 2008
0 characters
3 Points
Telefunken 5 plate gas stove with electric oven door does not close completely
contact Telefunken and ask them who repairs in your area
Oct 16, 2015 | Kitchen Ranges
Oven door will not close the whole way
Your oven door hinges(s) are broken, the springs that hold the door closed inside the hinges are either weakened or their mounting points have become worn.
You need to purchase a pair or replacement hinges which you can fit yourself if you have some basic mechanical skill. Don't try to just replace one side if you determine which side has failed as the extra strain put on the old hinge can cause the door to twist and break the door.
Mar 05, 2012 | Tappan Kitchen Range
Oven won't ignite
Your range is a Direct spark model.ce00970.jpg8278a1e.pngIf you want a Direct spark manual, let me know. The module gets confirmation from relay on the oven control and sends dc power to the gas valve. I suspect that gas valve be cause the top burners work which is usually and indicator that the module is fine. The terminals ohms should be 216 ohms between each of the 3. If any are open the valve won't work.
Jun 01, 2010 | Whirlpool GS460 Gas Kitchen Range
The oven door won't close JGS968
The hinges are sping loaded Take the door off to see how much he bent it maybe you can bend it back or the screws can adjust it.
Dec 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Upper oven door won't close properly.
You will need 2 new door hinges as they go weak after a time.and people tend to rest things on the door when open this will also weaken the hinges.they can be puchashed and fitted by anyone who is handy.(ie) not a big job only a few screws..hope this helps
Dec 20, 2008 | Kitchen Ranges
The oven door won't close properly, it just hangs slackly about 2 cm from the seal. it's a smeg wall oven.
the clips on these oven are canyilver type they can move out of position if opened abruptly .to refit correctly lift door upwards while pushing the bottom of the door should feeel a strong resistance from the door springs.there should be a notch n the bottom of the hinge this should slot over the oven frame.if this does not solve the problem then the springs have probably gone on the hinges and will need to replace both hinge assemblies
Jul 11, 2008 | Smeg Kitchen Ranges
Oven door hinge adjustment...?
Regarding the oven door not closing all the way and dropping suddernly to the floor, I called a local authorized service company and asked if there was a door spring (no). So the recommended solution is to have the hinges replaced. However, since the oven door didn't really hold its open position from the beginning, when it was brand new back in 01, I'm going to see if a new Viking oven has the same defect as ours. Then, it would seem like a good idea to take a chance on having it repaired.
Is replacing a set of oven door hinges something a person with reasonable mechanical aptitude can do?
Nov 24, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Jenn Air Oven Light Flashing
heat has weakened the springs on the door at hold it closed as tempertures change or people walk by the door light switch is activated the answer is to replace the door springs.
Aug 12, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Whirlpool RF378LXKS Electric Kitchen Range Logo
1,941 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
