Question about Xerox Phaser 8200 Laser Printer
Hp laserjet won't print under leopard.
Since i upgraded to leopard, my networked laserjet 5simx will not print. my daught can print under tiger when she plugs ethernet into her laptop so i know the printer is fine. how do i troubleshoot this?
Have you updated to the latest driver, I'm not sure the original driver for "tiger" would necessarily work with "leopard". There is an updated universal driver for all OS X versions.
Just a suggestion.
You can get it here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14991&prodTypeId=18972&prodSeriesId=25478&swLang=8&taskId=135&swEnvOID=219
Posted on Jun 17, 2009
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet Office Equipment & Supplies
I only get a black sheet of paper if I copy with my hp 1610
you will need to download the driver for leopard after you remove tiger
Aug 13, 2009 | HP PSC 1610 All-In-One InkJet Printer
Mac OS 10.5 Leopard
two issues here..
compatibility of Epson with Leopard..and also the drivers will need to be postscript compatible..not an easy task.
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Epson Stylus R380 InkJet Photo Printer
Can't print to 1410 after I upgraded to Leopard
I believe I had a similar problem. Try this:
Go to System Preferences > Print & Fax > '+'
Select the Epson 1410 and then under Print Using go to Select a driver to use the Epson Styls Phot 1410 - Gutenprint v5.1.3
I hope it helps.
Jul 25, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Installing hp 3550 printer driver on new OSX leopard system
When I try to print from an access data base to the laserjet color 3500 usb printer.
Tried diff. drivers, diff usb cable, it works for a while but after several test runs the error reapears.
PCL XL error
Subsystem: KERNEL
Error: ColorSpaceMismatch
Operator: VendorUnique
Position: 9
Mar 09, 2008 | HP Color LaserJet 3500 Printer
Scanner won't operate on HP PSC1410 All in one with Leopard
Hi, as per HP's support page on this product here
It seems that there aren't any drivers compatible with Leopard for this printer at the moment. The latest OS supported is Mac OS X Tiger... You will have to wait untill HP do something for leopard...
Mar 07, 2008 | HP Officejet J5780 All-In-One InkJet...
HL-5250dn ona Bonjour network will not work with Leopard
Brother is totally fucked up under Leopard, found so far no chance to fix it.  Brother's own printer drivers are 10.4 only -- lame
Feb 24, 2008 | Brother HL 5250DN Laser Printer
GCC 12/600 Not found under Leopard (on wireless network)
Same problem.
Plus I am trying to find a legitimate download for a 12/600 printer driver that will let me print from my new MacBook Pro running Jaguar.
Peter B.
Jan 07, 2008 | GCC Technologies Elite 12/600 Laser...
Xerox Phaser 8200 Laser Printer Logo
246 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
