Question about Whirlpool LHW0050PQ Front Load Washer
Door to washer won't open
The wash, rinse, spin cycles are over but the door to the machine won't open. How can I open it?
You just have to wait a few minutes after the spin cycle is over and the "done" light is on. At least that always works for me.
Posted on Jun 22, 2009
Why will my washer not spin in the rinse cycle
Because you have e too much soap and froth in the machine. The level sensor thinks is is still not full of water make sure that you don't over soap the machine and clearly ensure a filter is not blocked in the pump trap down the borrow of the front panel under the little door opening. Open this up and clear all obstacles . Good luck.
Feb 07, 2015 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Washer won't spin the water out after the rinse cycle
Probably the filter is clogged. It usually is at the bottom of the washer, either at the front or at the back of the washer, it normally looks like the fuel door of a car. You must open the metal door, release the lid (maybe at this point some water will come out) and then clean it. Put lid back, close the little door and try again with the rinse stage.
Good luck
Mar 24, 2012 | Kenmore Washing Machines
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
