Question about Refrigerators
Fridge goes from cold to warm
Smll pepsi fridge goes cold to hot fans are turning does it need freon compesser seems a little warm
  • 159 Answers
It seems like low gas in the system
Posted on Jun 17, 2009
Seals on my beco are hot to touch fridge freezer feel warm
Almost the same post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | Refrigerators
Hi is it normal that the middle Paleo that the doors close onto seems really hot? We have an American style fridge freezer, everything else seems ok, but I have never noticed it before!! Thank you
Again a similar post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Whirlpool model et18tk and the side of the fridge gets hot? It it junk?
APPLIANCE 911
Aug 15, 2016 | Whirlpool Refrigerators
Pepsi soda machine
could be low on freon, drity coil, rear fan not turnig,
Apr 10, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Fridge/freezer not working but light is on,located in garage,which iss v cold
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 10, 2010 | Refrigerators
Hi i have a lg split system air con model number lst243h-2 its nice and cold when i first turn on then its just like the fan is on its not cold at all
How long before it goes from cold to hot. The compressor could be not running and going out on overload. The condeser fan could have failed. Did you check the outdoor unit. Is it running? Is the fan running on the outdoor unit. It could be low on charge which would cause ice. Are you getting excessive condensation? Let me know and i can help you out more. Grab the large copper line outside that is insulated and tell me if it is cold. It should be cold like a Pepsi out of the fridge!
Aug 23, 2009 | LG LSC183VMA Split System Air Conditioner
Freezer on bottom cold but frig is warm
Just additional clues..(general). The defrost timers (on non-electronic) usually located at the bottom (underneath), have a tendency to fail. (One of mine is in the center, one was on the left side) There are usually about 5 wires connected to it. If it fails while defrosting.. the fridge will warm quickly and stop cooling, if it fails in cooling mode, you will have the icing up problem. (other) A squealing noise is usually a fan motor. -also- (Freon issues)..as freon is lost from a small leak, first the freezer will actually get colder, but the refrigerator section may be too warm (I know it sound stupid). When enough is lost the compressor will get hot and the fridge will not cool.
Jan 02, 2008 | Amana ARB8057CSL Bottom Freezer...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator not cooling properly
You may have a low freon condition in the fridge section. Look to see if you have an ice block building up on the rear wall towards the lower left side. If so, you are low on freon and the ost likely culprit is a leaking evaporater. The best way to tell if you are low on freon for sure is to take out all the shelves, remove the light cover, then the 2 screws holding the fan cover, and then remove the back wall. You wont be able to pull it all the way out cause the cold control is attached to it for the freezer and fridge so be careful. Turn the fridge control all the way up to 10 and wait till the compressor is running. you can tell if the compressor is running by pushing in the little switch on the top of the door frame and seeing if the fan runs(one switch is for lights, the other for fan) if it runs the compressor is on. anyway watch the coils and see if they develop frost all the way from top to bottom. If they dont you are low on freon and are ooking at about a $600 repair. if it does frost all the way you may have a bad cold control or a stalling fan motor up by the condensor on top. The best way to tell this is the next time the fridge feels warm, sheck the frame around the door seal and see if it is hot to the touch. If it is you almost surley have a bad condensor fan motor. Hope you can wade through all tis to find the answers. Good Luck!
Feb 21, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
