Carrier Infinity control went completely blank. Noticed it earlier. No matter what I push there is nothing there. Have tried manual with no luck. Any ideas how to reactivate the system? Had no noticeable problems before this. Just went blank.
    Sergeant:
  • 340 Answers
Circuit breaker tripped control fuse in furnace blown cause would be short circuit. lastly bad control
Posted on Jun 17, 2009
Carrier infinity thermostat went blank when I touched my finger on the fan button and a static charge jumped from my finger and the screen went blank. All functions are working except the screen.
Every issue I've had with the Infinity has been a strange one. The blank screen is something I've seen and it was just a month ago. But I have no idea how I fixed it. Screen was blank but had the back light illuminated/was green but no numbers or letters displayed. I removed the tstat from its base, checked the pins on the back to see if any were bent or damaged. Tightened all wire terminals. Checked for 24v(present). Reinstalled to its base. Walked to my work truck and downloaded a manual. Walked back inside and the screen was now visable, with all numbers/letters present. I'm guessing I reset it by removing it from its power source? Also, at the indoor units' control wire terminal block, there is an A B C D. And most installers will connect 2 wires in each of these terminals. This is not correct and will give trouble due to a lost connection. You can try to tighten these low voltage terminals A B C D. The correct way to wire is at A, 1 wire is connected. That 1 wire is then connected to the 2 wires with a wirenut. B C D should be in the same way. 2 wires in this 1 terminal WILL lose connection and not communicate with the tstat. If this don't help, the tstat may need to be replaced. Hope this helps!
Mar 13, 2017 | Carrier Heating & Cooling
I have a whirlpool built in oven. Model RBD275PDQ8. The display (control panel) went blank 2 months ago. I reset the breaker, nothing. Pushed buttons, it just beeps. 3 days later I pushed the upper oven...
it's the control panel behind that touchpad item. and it's not too difficult, just time consuming. My recommend is to grab a service manual online(usually around 20.00) which will provide good step by step,and also parts list.
spares? well, that's a good question. Until you have that part number, and the best way is to eyeball the one that's in side your unit(no offense to the printers, but mistakes can happen with manuals).
then you'll find out what it's like to be truly handy, eh?
May 31, 2008 | Whirlpool Kitchen Ranges
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
Zone control not working
These are both power open and closed. Yellow and green should be constant on the leds. C&D is your 24 volts for the controls. If you got power going in but nothing coming out of the board it is bad. If you got 24 going to the damper but damper not responding obviously it's bad. Usually communication is DC voltage, likely 12 or 13 DC at A&B. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 13, 2017 | Heating & Cooling
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Jul 18, 2010 | Heating & Cooling
Toshiba satellite display problem
ur computer is stuck in resume mode and since there are not all the files on harddrive when it went off so what you need to do is this as soon as it powers on at Toshiba screen keep on taping F8 and then select delete restoration data after that it should boot up fine.
Thankyou
Nov 26, 2008 | Toshiba Satellite A60 Notebook
Unit/control panel completely dead
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Jan 28, 2008 | Carrier 38CKC042 Air Conditioner
LG VX8600 SCREEN WENT BLANK, PLZ HELP!!!
m8 sounds like your screen is faulty or your ribbon has been damaged in some way.to fix it you will need to open it and have a look at the ribbon if there is any damage vissible no matter how small it means ur ribbon is gone an you need a new 1.it could also be your screen if there isnt any damage on the ribbon then it could be the screen.it could be a combination of both. word of caution: if you try to open it yourself you could damage the ribbon.you wont notice it but its very easy to do.so be carefull. but if you want an expert to do it for try these guys http://www.mobilephoneservicecentre.co.uk/ good luck
Jun 18, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Heating & Cooling Logo
377 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
