Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
My frigidare dishwashers ultimate scrub cycle will not work
4 Suggested Answers
  • 415 Answers
SOURCE: frigidare dishwasher
can you give me the exact model # on your dishwasher and i will check for you.
Posted on Sep 13, 2008
  • 6 Answers
SOURCE: frigidaire pld4375rfc2 dishwasher
don't buy this manufactors products the are not weel made!
Posted on Sep 28, 2009
rohntech
  • 422 Answers
SOURCE: my frigidare dishwasher runs, but
make sure the machine is clean free from foreign deposit like soap, tiny particle of food, etc. check the button control for some lose connection, wire etc.
Posted on Jan 29, 2011
Bosch dishwasher model SHX46A why does the on/off switch and lights stay on while the dw stopped running?
The dw was not quite running. It does pause between cycles. The power scrub cycle means that you had the machine on the longest of all cycle choices. There's almost always a light and a normal cycle. The pots and pans cycle is a power scrub option. Yes all the lights would be on until they switched to a different part of the cycle. Do you have a DRYING light? That would be the one to look for as far as the dw being finished. :)
Nov 20, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
My frigidare dishwasher runs, but the washing cycle is not working
Jan 29, 2011 | Frigidaire Dishwashers
I have a Bosch SHX46A05UC/33 5-cycle dishwasher whose labels on the cycle buttons have also worn away. While the Macmarkus post was helpful b/c I have some of the same buttons, can you tell me the labels...
Some SHX46A washers have 4 cycles and others have 5 cycles.
I'm fairly sure your model has the hidden buttons on the top of the door and you stated you have five-cycle buttons, in which case they will be as follows.
1. Top Rack only cycle or Sanitize
2. Power Scrub Plus
3. Regular Wash
4. Delicate Wash
5. Rinse and Hold.
These buttons are also used for cancelling a wash cycle. Hold down "Power Scrub Plus" and "Delicate" at the same time to cancel a cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration (from left to right) will be:
1. Power Scrub Plus
2. Regular Wash
3. Delicate Wash
4. Rinse and Hold.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Nov 21, 2010 | Bosch 24 in. SHX46A05UC Built-In...
It is stuck between cycles. How do i reset?
Have you tried turning the mains power off and on after a short delay?
If this does not work then press the following buttons in quick succession (about 5 sec) and when all lights light up press Cancel.
HIGH TEMP SCRUB, AIR DRY, HIGH TEMP SCRUB, AIR DRY
Oct 22, 2010 | Whirlpool 24 in. GU1200XT Built-in...
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire pld4375rfc2 dishwasher
Aug 26, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwasher not cleaning the dishes
have you cleaned the fliter in the bottom
Feb 15, 2009 | Frigidare FGB24S5DC Gas Single Oven
Wash Cycle Not Working
Either the wash motor plug is loose or the motor itself is bad.
Dec 11, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidare dishwasher
Sep 03, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Bosch Dishwasher stuck in "Scrub Cycle"
The Control module on our SHU43 blew this morning and when I took it apart to get the module out, I discovered why two of the Cycle selections no longer worked..... the little plastic lever that pushed the switch behind the fascia button - had broken off. You may have the same issue. It's not a cheap fix though as a new module is gonna cost me $175.
Mar 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
65 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
