Question about Dell E152FPc 15" TFT LCD Flat Panel Monitor
Monitor powers on for appx 1 second then goes dark. LED is on.
The green light stays on, but the screen goes completely dark after 1 second. Only by powering off then powering back on the monitor can I see my screen...for about one second than it starts all over. Cables all ok. Tried adjusting the display rate to 70Hz as one solution recommended but no difference. Monitor behaves this way on any computer it is tried on. Capacitor problem??? Transistor problem??? Bough this thing used and I was told it worked fine. Not!
  • Chris P. Jun 17, 2009
    Thanks! I will try taking a look and see if its do-able for me, although I am an inexperienced solderer.
  • Dell Master
  • 1,684 Answers
You have a classic capacitor problem. If you are ok with soldering you should be able to repair it. You can remove the back cover and look for the bad capacitors, replace any that are raised on top. I can send you pictures of what to look for if you need them.
Posted on Jun 17, 2009
  • Buddy Mcsparrin Jun 17, 2009
    If you don't feel that you can do the soldering for this unit let me know we offer a repair service and I can replace your bad caps for $15.00 plus return shipping.
    Buddy
    buddy@ccl-la.com
I had this same problem and found a capacitor on the power supply board was bad. The cap was a 1000microFarad 16V bi-polar capacitor with a temp rating of 105°C. No one in this town had a 105°C the highest temp rating I could find was 85°C so I used that. So far it's working but I don't recommend ever going with a lower rated part. The hardest part of the whole job was getting to the power supply board. Dell has some tricks to getting inside this monitor. Good Luck.
Posted on Jun 26, 2009
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Jun 07, 2013 | Computers & Internet
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
My screen will not come on
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
More information in: http://lcdinverter.info
Feb 26, 2013 | Archos 70 Internet Tablet
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
When I plug the monitor in the power light goes on yellow/brownish for a second then goes green for a second then shuts off, the monitor almost turns on, you can see something come on the screen, then the...
The problem can be bad power supply due to bad caps, bad inverter circuits, or bad lamps. Open it up and look for bad caps first then report back what you see so we can guide you further, see example of failed monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Feb 01, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a older kds lcd monitor that goes black less than 1 min after turning on, the power light stays on, the monitor will come back on if you repower the monitor then goes back off in 3 or 4 seconds. Is...
if you look closely can you see a very dark image on the screen? your problem is usually the result of the backlight on its way out, these are very hard to replace so you will need to take it to a profesional, in most cases it is cheeper to buy a new screen.
Jul 02, 2009 | KDS Computers & Internet
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Dell E152FPc 15" TFT LCD Flat Panel Monitor Logo
457 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
