Question about RCA TruFlat 27F520T 27" TV
My tv turns on and off repeatedly. (automatically)
The tv turns on and off by itself. The remote control will not function when this happens. The tv will turn on and "channel search" , and turn off. I 've had no choice, but to unplug it all together. What should I do?
  • jivejunkee5 Jun 17, 2009
    Thanks for the input. I decided to disconnect the wires between the front controls and the main board, gave it a thorough dusting, and now rely on the universal remote for the cable box. So far it has worked decently. I guess it will do for now. Thanks for the input.
    Top Expert:
  • RCA Master
  • 81,400 Answers
Sounds like the infrared sensor in the set has a problem, i would replace it.
Posted on Jun 16, 2009
  • Marvin
    Marvin Jun 17, 2009
    it is the sensor throwing spikes, if u want to fix it replace the infrared sensor in the set.
Targa Visionary LT 3220 television is stuck on mute. tried pressing mute button on remote but nothing happens.
Unplug the TV for 5 minutes and see if it clears. Is there a mute message icon on the TV screen (picture of a tiny speaker with a line through it)? It turns off anytime the volume control is touched automatically, so if that doesn't happen you have a problem with the TV itself.
Aug 18, 2016 | Televison & Video
How to tune channel when channels are locked?
The Sony KV-36HS510 has an Auto Setup function for the channels.
1 Press POWER to turn on the TV.
2 Press TV FUNCTION on the remote control.
3 To continue running Auto Setup, press CH+. To exit Auto Setup,
press CH-.
Auto Setup automatically creates a list of receivable channels. When
finished, the lowest numbered channel is displayed.
To reset the TV to factory settings
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
Apr 14, 2016 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I need a code for my panasonic tv my remote is rm-88e
Hi julius,
If you don't have a code follow this auto search mode, this will automatically search the remote control the code of your unit.
1. Power on the unit(TV).
2. Press and hold SET key and TV key at the same time. The led light will be on at the moment, then released the pressed key.
3. Press the SET key again, then release it. The led light will flash and it is in the quick search mode.
4. Point the remote control to the TV, then press the POWER key(every second) until the TV react. Once the TV reacted try the other function key.
Repeat the steps until you've got the right code.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 25, 2011 | Universal Remote Control Remote Control
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
Remotes will not work
change sensor of your remote control ,if there is not solve than change your sensor of your tv
Jun 02, 2010 | LG 42PG20 42 in. Plasma HDTV
Wega turns off and on by itself,
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Jan 24, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Brookstone remote and I need the code
You'll have to try a few: 073, 075, 078, 081, 082, 083, 084, 092, 096, 103, 104, 105, 106, 108, 114, 117, 119, 125, 129, 130, 131, 134, 139, 144, 146. Or use "automatic coding": turn off appliance, hold down function key on remote (ex., TV) until red light comes on, press & release OFF/ON, press Channel + continually and slowly until appliance turns on, press OK to lock in this setting. Repeat if this doesn't work.
Oct 17, 2009 | Brookstone 538744 Remote Control
538744) Remote Control Jumbo, I need the code for a Phillips TV/can you help me?
You'll have to try a few: 004, 005, 029, 030, 072, 073, 078, 080, 087, 118, 153. Or use "automatic coding": turn off appliance, hold down function key on remote (ex., TV) until red light comes on, press & release OFF/ON, press Channel + continually and slowly until appliance turns on, press OK to lock in this setting. Repeat if this doesn't work.
Jun 12, 2009 | Brookstone 538744 Remote Control
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
RCA TruFlat  27F520T 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
