Question about HP OfficeJet 7310 All-In-One InkJet Printer
Paper jam, rollers will not move, HP Officejet 7310 All-in-One printer Please email me with solution at: kennethhamilton2003@yahoo.com
    President:
  • HP Master
  • 1,996 Answers
See solutions on HP online support site here, here, and here.
Home support page here, for other issues.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 16, 2009
Paper feed continues to jam on left hand side facing
hello my friend! paper jam is cause by something that is inside in your printer. try to check the roller of your printer and clean it,
Jan 21, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Printer keeps saying paper jam hp deskjet d2560
make sure rollers are clean, make sure no paper is stuck in the rollers on the back and the top. Make sure using the right type of paper. Clean the rollers if they have dust or lent on them.Reset the printer. If these steps don't correct the issue call your warranty company if you have a warranty on your printer as they will cover this.
Mar 13, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One Carriage Jam
I think you need to clean the back rollers of the printer.
Follow this hp document and it should clear up the issue. The error is for out of paper but the fix is the same. Step four is the one you need.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&jumpid=ot_recdoc/c00219180/en_us/c00786157/loc:4&custom_solutionid=rd_c00219180&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=391182
Jan 28, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310 allinone
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Officejet 7310, ADF will not operate, no movement of upper roller
Lift up the cover to the automatic feeder.
You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it.
Then you will be able to see of there is any jammed paper, which which can be pulled out carefully with a pair of tweezers.
Some may be under the rubber rollers.
Jan 15, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage Jam
Without knowing what type of printer we are dealing with, what paper try layout etc etc.. I would suggest you try replacing your pickup rollers.
Nov 23, 2008 | HP Officejet 7310 All-In-One Printer
Paper jam in carriage
There is a latch at the back of your printer that opens so you can remove paper jams from the back. You can start there and then slowly peel away the rest of the paper that jammed...
Mar 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
97 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
