Question about Garden
Green Thumb Dubl-Tine rototiller won't freewheel
I bought this tiller used. There's no manual with it. When I want to move it, I have to start the engine, engage the clutch and walk it at a snail's pace to where I want to use it.
I'm wondering if there's a lever somewhere that will alow me to 'freewheel' the axle (without starting the engine) and just push the tiller to the worksite at a quick pace.
Http://www.toolpartsdirect.com/mtd/mtd-77.html
Lots of info here, check your Green Thumb Roto Tiller's "Model #" (for example mine is #53GT-F) , and look on the site I linked to , good chance they have it in their database, have a ODF exploded view of it , and have parts available.
Hope this helps.................Blake
Posted on Aug 08, 2012
  • 3 Answers
You can turn the wheels around and it will free wheel but you would have to turn them back around when you get ready to
till the ground. when the wheels are reversed you can push it without the motor running. hope this helps
Posted on Mar 13, 2010
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
New tiller makes grinding noise when trying to run tillers
if it has a clutch
most small units just run a dog that you engage with a swift motion at low idle speed of the motor
have the tillers free above the dirt so they can turn with out any load to inhibit the dog engagement
May 20, 2015 | Garden
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
When installing clutch drum, it turns with the drive shaft
Hello , well you again, on some of the small tillers the tines will engage because that is the way they are made to do on start up,it is not a clutch issue,ad far as i know there is no way to disable this,it is a pain but this is the way it is,,hope this helps,
Jan 30, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
PULL CORD START SYSTEM ON ENGINE SLIPS & DOES NOT ENGAGE CLUTCH
Take it to Home Depot and ask for a replacement if it was just purchased , otherwise just let them repair it.
brucewo
Jul 05, 2010 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Need a user manual for Earthquake 3365PS tiller
I need a service manual for the earthquake 9800 auger with the 3.8 hp tecumseh.
May 12, 2010 | Ardisam 5.5 Hp Rear Tine Rototiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Replace belts on Montgomery Ward rear tine rototiller Model number GIL39012B need diagram
Go here and you can download a free manual for your machine.
http://lawnandgarden.manualsonline.com/manuals/mfg/montgomery_ward/tmo39083a.html
Oct 24, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Garden Logo
853 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
