Question about Sony DHG-HDD250 200-Hours Video Recorder
Frozen buttons Sent to Sony in Mar 2009 for no clock or channel update AFTER 9012 reset. They did the same 9012 reset and returned to me - still frozen. A week after the unit was returned to me, the clock started, and the next day channels started filling. Three months later ,June 2009,everything froze up again. No button function & clock frozen. I installed new 1.2.21 ?? software upgrade which verified it was correct. I could Manually record and watch a show that day. The next day again no buttons or clock worked. I tried "Exit + TV Guide" reset and also unplugged for 30 minutes. Nothing. Sony will call in 5 days with an offer since this has been repaired 2 times under warranty.
    Problem Solver:
  • 10 Answers
I think you may need to buy a new unit not on a sptial
Posted on Dec 10, 2011
How do I set the clock on my ccr1cd?
stevej9_98
SOURCE:need instructions for Wharfdale ccr1cd micro clock alarm
Press the STOP/CLOCK button for about 3 seconds till the hour number flashes
use the forward and reverse buttons to set the time on the hour
press the stop/clock button again to move on to minutes numbers
use the forward and reverse buttons to set minutes
Press the stop/clock button again to complete process
Posted on Mar 28, 2010
May 27, 2018 | The Audio Players & Recorders
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Okay I've purchased a 40 inch tv today and how do I reset everything?
From the User Manual, page 35 (page 36 in the .pdf file):
Return your settings to default values When you return picture and sound settings to their default values the
channel installation settings are not affected.
1 Press MENU on the remote control and then use [the arrow buttons] to select [Setup] > [Installation] > [Reset AV settings] > [Start now].
2 Press OK to reset the picture and sound settings.
3 Press MENU to exit.
You can download a copy of the manual from 40pfl7705dv_f7_dfu_aen.pdf http://download.p4c.philips.com/files/4/40pfl7705dv_f7/40pfl7705dv_f7_dfu_aen.pdf
You may also want to look at "Update your TV software" on the following page of the manual. Updating is not always necessary, unless the update fixes something that bothers you or provides an improvement you want (if it isn't broken, don't fix it). As of this writing, there are two sets of fixes (copied from the "Firmware Upgrade Readme File" at Software & drivers):
Software history:
Version: Problems solved.
PHL-0DA_710_0 - Momentarily looses audio after channel change.
- Time shifts one hour when changing from "Auto Clock" to
"Manual".
- Enables Philips Wireless Media Connect.
PHL-0DA_713_0 - Clock does not keep accurate time.
You do not have to apply both updates; everything is included in the latest one.
Jul 24, 2014 | Philips 40Pfl7705dv/f7 40-inch Smart...
My sony handycam DCR-HC26 is frozen on "clock set"
Hello i am hamid
I need a drive for Windows 7 Help me please
hamid.far12@yahoo.com
Jul 07, 2010 | Sony DCRHC26 MiniDV Digital Handycam...
Reset Margins
on the upper L.H. side of the key board ther is a button marked MAR REL. turn typ. on press the return key then press the MAR REL key back space to move the carrier backwards or space bar to go forwords. when you are at the spot you need to be fined the button that reads L MRG. press it know your left hand margin is set,
know space the carrier over to the left by the space bar if it stops befor you whant it to press the MAR REL button space to where you whant.
now you have another button saying L MAR
press that and you left hand margin is set. Or the R MAR has small green letters saying L MAR if so you need to hold down the CODE key wile pressing the R MAG key ( any thing in green on key board can only be actavated by the code key ) hope this works
Jan 21, 2009 | Brother GX-6750 Typewriter
F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Frozen
hi mine freezes too when i try to open my photos on the walkman. but mine did work using the reset button, you might want to return it if you have receipt, if not you still got 1 year warranty with sony.you can also try connecting the player to the computer to see if it turns on and charges. thanx
Dec 25, 2008 | Sony Walkman NWZ-S616F MP3 Player
Sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Jul 19, 2008 | Televison & Video
DHG-HDD250 problems when recording
When I'm watching a recording program and recording a program I can't fast forward, pause, stop nothing works until the program that is recording stops.
I reset the machine, but it did not help.
Feb 26, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Sony DHG-HDD250 200-Hours Video Recorder Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
