I think one of my employees got glue or something onto the staples inside whilst using it - I need to open up the loading mechanism to clean it as the staples do not move into position by means of the spring as they stick to the rail. if I jiggle the spring loader I can do 1 staple and then need to jiggle it again to get the next one to staple
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
SOURCE: Just purchased t27 arrow staple
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
SOURCE: how do i open the
Angelbabie...Like most things, it's pretty easy if you know how.
1.Release the loading latch located on the back end of the staple gun by pinching it with your thumb in a downward motion. This will release the catch and allow you to pull the loading slide out.
2.Hold the gun upside down (so the staple don't fall out) and place a stick of staples in the bottom of the channel which will be exposed once you pull back the loading slide.
3.Push the slide back in and make sure the latch is engaged. All good to go!
Happy stapling.
SOURCE: Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
SOURCE: I need staples for my
The big box stores (Lowes, Home Depot, etc) don't carry the full Stanley line. Ace and TrueValue (or equivalent) may carry staples for this unit.You can always find them online. Amazon will probably have them.
DIYpro
