Question about Sharp Aquos LC-32D40U Television
Same Tv same issue
I have the same TV as this guy does with the same connection over component to the TV. The TV would blank out for about 2 seconds and then the video would come back with the input information in the upper right part of the screen. This does not happen in the xbox dashboard but only in a game. Unfortinately my xbox 360 is one of those "pre hdmi" versions so I can't use hdmi. i am going to get a new xbox soon to fix this issue. I also had to scale down to 720p to reduce the blinking out issue but it still happens every once in a while. i had a smaller hdtv before I got this tv and never had an issue like this before. My PS3 is hooked up though HDMI and haven't seen any problems with the connection so I think its an issue with the component to the TV.
  • 668 Answers
You may also check with Sharp's Customer help line to see if there are any software updates for this unit. They can send it out via SD card with instructions.
Hope this helps,
Skyassoc
Posted on Jun 17, 2009
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
S video displays, but Component video is intermittant
Shall we assume that the DVD is fine, before addressing the TV issues? Does it work with any other device or component? Seems that if your S Video is clean, then it's just a matter of refining whether your DVD is as well. Check that, and let us know.
Feb 12, 2008 | Hitachi 53FDX01B 53" Rear Projection...
I have a Sony KDS-60A2020. TV went blank. No flashing lights. I have sound, but the screen is blank.
have you tried a power reset, unplug all components from the TV unplug it from the wall, then push and hold the power button for about 30 seconds, then plug all components back in, plug it into to wall then turn it on again.
Jan 14, 2012 | Sony KDS-60A2020 60" HDTV
We have a VIP 722 and the second channel is now without sound. We have sound on channel 1 but not 2. Any ideas?
Step 1: Check that TV or Stereo is not muted
Make sure that your TV or Stereo has not beed muted and that the volume is turned up loud enough to hear.
Step 2: Reset Receiver
If the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
Please note: It may take up to 5 minutes for the reset process to be completed.
Step 3: Check Receiver-to-TV Configuration
Check that the wiring between your DISH receiver and your TV is configured properly.
Step 4: Secure Receiver-to-TV Connections
Check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure.
Mar 10, 2011 | DISH Network ViP722 DTV Receiver /...
Hi guys, I bought new HD TV I have Dish receiver,# VIP211hd. Tv is not seeing HDMI signal. Tried three diff cables into all 4 ports on tv. DVD player works in any of them .Dish tells me output is port...
This is a really difficult problem to answer correctly on the first try but here we go. Some tvs will not recognize the introduction of a new component without unplugging the tv for about 30 seconds with the component connected and powering the tv back on. The issue I believe Dish was trying to convey was to make sure the port you plug the receiver into is turned on in the tv menu. Since the dvd works in any of them this seems to be the case. I f you have further difficulties you should contact the tv manufacturer for assistance as they are more familiar with teaching the tv to communicate with the receiver than Dish personell will be in most cases.
Jan 30, 2009 | DISH Network ViP 211 DTV Receiver
PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Can't connect psp component cables to tv
okay. here's what you need to remember as i encountered the same issue and had it resolved.
1. connect the psp tv out component cable to the tv. make sure you have every cable in their correct plug-ins.
2. on your tv remote, press output until your tv displays the correct output data info. it will display component 1 or component 2. make sure this aligned with where you connected your component cable.
3. turn on the on the psp, then press and hold the display button ( it is near the start and select buttons on your psp, with a box like icon. after 5 seconds, it will give you a gray screen with a box icon and an arrow which means you are transferring the data out from the psp to your tv display.
4. enjoy your psp on tv!
Aug 08, 2008 | Video Game Consoles & Games
Video blanks out TX SR605
I had the same thing happen with my SR705. I ended up hooking the video to the tv and leaving the audio to the receiver. Haven't had trouble since
Jul 24, 2008 | Onkyo TX-SR605 Receiver
SHARP aquos 1080p HDTV: VCR image flickers when playback
Well I do not know either machine but suspect if the video is old either your video's output is too rough for the TV because:-
It has some age related problem of wear.
The output signal is not quite correct in quality.
There may be a security signal applied on its recording material.
These are some of the issues, videos are very sloppy (by todays standard) but could get away with it with analogue TV's because of wider design variables inherent in that system.
Modern TV,s are less hardware more software driven and as such are critical about errors going to a blank screen as a way of escape an issue they can't resolve (mummy mummy!).
The video may need checking for mechanical or electronic issues, a favourite being power supplies which can generate noise from defective components that disturbe other equipment, or mechanical alignment which changes through wear and time.
You could try conversion to hdmi signal though cheap converters are limited in their method of doing this but might show you if it would work.
Cheap versions are about £10 but have no level controls (contrast, brightness or colour to trim for best picture)
Hope this helps............
Apr 27, 2017 | Televison & Video
Televison & Video Logo
144 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
