Question about GPX DPI iLive IHMD8816DT for Apple iPod
Ilive ihmd8816dt - cd/dvd drawer doesn't open
The cd/dvd drawer doesn't open and it doesn't even change into the dvd/cd mode anymore.
Thanks,
Christina
My Spirit of St Louis CD, Radio and cassette player is great. However the CD player won't open anymore. How can this be fixed?
Are you opening by pressing manual control or by using remote control? Quite often there is a small ' pinhole aperture next to the DVD drawer - if so , use a straightend paperclip to push into the hole in order to release the drawer.
Oct 21, 2016 | Miscellaneous
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Just got an LG GH22lp21 and it will not read a single disc. It will not even read the Drive Install Disc. It will burn no problem, but won't read. I cant find a driver anywhere. Thanks
Just click on the link http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
and also click on NOW RUN from right side box. It will automatically give youthe message, well or bad.
If the problem with the lens, you should try cleaningthe lens,with disk cleaner, it's already gone bad and there is no harm to take a risk to open ordisassemble the dvd/cd rw,click on the bellow link http://www.youtube.com/watch?v=WaiTJYHQCCg
  1. When running your pc, open the drawer.>
  2. clean the optical lance
  3. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
  1. now you can fit to your pc
If it does the same problemplease change the cd/dvd rw because the lance has defected. If you need more information, reply me soon.
Thanks .
Feb 25, 2011 | LG 10PK GH22LP21 DVDRW DL LIGHTSCRIBE 22X...
Cd drawer will not open
To open your cd drawer.On the front of your cd you will see a small pin hole,straighten out a strong paperclip and push the end through the hole,and this will release the catch and open the tray. Push hard as the catch will be quite stiff. Hope this helps you.
Regards Bill
Mar 14, 2010 | QPS Que! USB 2.0 Drive CD-RW Burner
I bought 2 brand new players rca drc277. Neither one will open the drawer. by button or remote...???is there some code to get it started?
Hello cheekarae,
There is no code to get it started for the first time. If you bought them brand new from the store then you need to return them and get new ones.
If you purchased them off of someone, then I would almost assume they sold you bad dvd players.
The reasons for a cd tray to not come out are A. The motor that turns the gears is not working properly thus not opening the drawer. B. The gears aren't connecting properly and are unable to push the drawer out like there supposed to. (Typically you will hear some clicking or grinding noises if this is the case).
Sorry about your luck, I would look towards replacing them for some that function correctly from the get go. Post back if you have anymore questions. Thank you for choosing Fixya!
Jul 14, 2009 | RCA DRC277 DVD Player
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Nov 05, 2008 | Computers & Internet
Toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
May 22, 2008 | Toshiba SD-3990 DVD Player
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
GPX DPI iLive IHMD8816DT for Apple iPod Logo
156 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
