Question about Moen 10790 Lavatory Faucet drain assembly, brass, Chrome
Can't remove moen bathroom faucet assembly to replace it. can't figure out how to seperate it from the sink...
    Problem Solver:
  • 6 Answers
If you are dealing with the type of Moen faucet I think you are, what you need to do is remove the pop-up rod. do this by loosening the locking bolt on the linkage under the sink and pulling the rod out from the top. Once the rod is out you will need to find the correct size allen wrench which goes into the center hole. there is a mounting bolt in there that needs to be unscrewed. Easy when you know how.
Posted on Jun 17, 2009
How to remove bathroom single handle faucet ?
  1. Shut off the water supply
  2. Disconnect the supply lines
  3. Remove mounting hardware from underneath
  4. Pull the disconnected faucet assembly up and out of the sink
Jul 17, 2014 | Moen 4621 Chateau 1 Handle Bathroom Faucet...
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
My bathroom faucet leaks a drop of water every 30 seconds
If you live in a hard water area, you probably have some buildup on the seals. You might be able to clear it by just running water through it, but most of the time, you might have to take the faucet off and soak in vinegar or replace the seals/cartridge.
Sep 26, 2011 | Moen Bathroom Sink Faucet - 4-inch...
Moen 2 handle bathroom sink faucet, ca84004 series. cold faucet functions fine. hot faucet does not shut off. handle turns as cold does but hot does nothing. water must be shut off from wall supply...
Try going to their web site and selecting consumer support. Usually the bathroom sink faucets, you can unscrew the handle with a Phillips screw-driver and then twist the body of the faucet off. Then there will be a nut to screw off, to remove the inner "guts". It sounds like the rubber seal is worn out on the inner faucet assembly. If so, then all you would have to do, is to replace the rubber seal. I hope that this helps you out. If not, then I would contact the company and see about a replacement faucet, depending on your warranty! If worse comes to worse, then I would call in a professional plumber, to assist in fixing it! Good luck my friend.
Jul 06, 2011 | Moen Plumbing
Replacing the handle adapter on a 4-inch moen monticillo bathroom faucet. Can't get the handle hub to unscrew with a strap wrench. tried using lime away to cut the 15 years of crud around the handle...
Sometimes there is a small set screw located on the handle.It takes a small allen wrench to loosen it.That should enable you to remove the handle assembly.
Jun 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
When I turn on the cold or hot water sink faucet water leaks out from the top of the cold water faucet . I took the outer casking off and can not figure how to remove the stem. I removed the ring but...
if you have the ring removed, screw the handle back on and pull up on it,, your leak is probably due to a worn , torn , "O" ring,, and Moen parts are found at most hardware stores ,, ( including Home depot , and Lowes) On Moen faucets , Look for the dent in the flange that squares off,, where that square is on the ring, is where the retainer ring is that holds the faucet in place ..its a "C" clip with a head on it, remove this ring and the assembly should come out , be sure and use plumbers grease when replacing the O rings,, they last much longer that way
May 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Moen 10790 Lavatory Faucet drain assembly, brass, Chrome Logo
597 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
