Question about Saws
I need circuit breaker for table saw model 137.248830
  • 58 Answers
Table saw will run a couple seconds and the thermal reset breaker throws - no problem w/ incoming voltage, I guess it needs replacing?
SOUNDS like if a breaker is thrown,it is possible that you are overloading that branch circuit(meaning there are other working outlets on that circuit) SOUNDS like breaker is working fine.
Mar 13, 2015 | Saws
Ryobi 10 inch table saw trips breaker when he turns onRyobi 10 inch table saw trips breaker when you can it on
First of all the saw needs to be plugged in directly to a outlet . NO Extension CORD !!! If it is Right , then Check on the motor label and see how many AMPS the motor is ? You need to then check the Breaker box and make sure the breaker is big enough to handle the load of the motor on the saw . You may have to make sure that the saw is the only thing on that breaker . NO Refrigerator , A/C , ECT.
Also make sure that the motor is clean and not packed full of saw dust . This can over heat the motor and kick off circuit breaker fast .
Good Luck , Hope This Helps !!!!!!!!!!!!!!
Aug 22, 2014 | Saws
Circuit breaker trips out
What is the rating of the breaker? Is this enough to run the saw? If this is ok, has the motor become damaged or has the blade got dirt or wood dust slowing it down?
Jul 25, 2014 | Hitachi C10FR 10" Job-Site Table Saw 15...
Trying to cut any size piece of wood the saw blows the circuit breaker at the panel 1x4 piece
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
Apr 13, 2011 | Craftsman 10" Table Saw
The table saw shutdown where is the restart button
Usually the reset for table saw is on the motor itself
Crawl under the table and check it out & check your motor name plate (use a digital camera to photograph the name plate so you can see it large on your computer and have a record of that information)
Look for oil caps at the bearing ends of motor, to see if your motor can be oiled using 3-in-1 oil
If your saw is shutting down, you may not have enough electricity for the motor
Look at motor name plate for volts amps or watts.
Now figure how much electricity your saw need using the formula Volts x Amps = Watts
Next, look at the circuit breaker and size wire
15Amp breaker = 1440+watts
You can figure the breaker load using V X A = W
Next look at your wire going to table saw
14 gauge wire for 15 amp breaker
12 gauge wire for 20 amp breaker
10 gauge wire for 30 amp breaker
You might benefit by running bigger wire to the saw. And adding some oil in the oil caps.
I oiled my table saw and then ran a dedicated 30Amp wire to it, and it runs real good for a 25-year-old craftsman.
Oct 20, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
I can't find the reset button.
Go to this URL.
http://www.ereplacementparts.com/dewalt-dw744x-type-table-saw-parts-c-1009_2657_3818.html
On page B of the parts listing (top of page), item 213 is the circuit breaker. Looks like it is on the front, perhaps lower left. Just a small button type circuit breaker.
Sep 17, 2010 | Dewalt DW744X 10" Portable Table Saw
20 amp Circuit breaker trips everytime I flip the motor switch on. Its a craftsman table saw motor 1HP Model 113-12070., 14/7 amps
I assume that you are using the motor on 115 volt service. Remove the drive belt and check for excess friction in either the saw arbor bearings or the motor bearings. If both seem free to turn, then suspect that the start capacitor on the motor has failed. They usually become open circuited which prevents the start rotation. It will just sit there and hum loudly until the breaker pops. You may also have a defective 20 amp breaker--you will need a clamp-on AC ammeter to verify. Suggest that you run the saw on 230 volt service when you get it running. You will be amazed at the acceleration and apparent power available. My table and radial arm saws are both set for 230 volt operation and love it. Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of drawings that list all replaceable parts. Hope this helps!
Jun 27, 2010 | Craftsman 10" Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Does not turn on. The wood was at an angle and jammed when it quit working
Hello. I recommend that you check your circuit breaker or fuse which is in the house panel and feeds the outlet that your saw is plugged into.
I believe that you will find that you solution is to reset the breaker or change the fuse.
Nov 28, 2009 | Craftsman 10" Table Saw
B&D 8 " table saw doesn't work
Hi, You need a 30amp circuit breaker. That should do you just fine.
Thanks for using FixYa
Nov 10, 2008 | Saws
Saws Logo
96 people viewed this question
Top Saws Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
