Question about Makita 12 Volt Cordless Drill/Driver Kit
I can't unscrew the bit?
I have a makita drill and don't remember how to get it to unscew to change bits
    Problem Solver:
  • 7 Answers
Just above the operating button there should be a lever that pushes left to right.
Posted on Jun 17, 2009
Makita HR2450 drill all functions working fine drill bit will not lock in
Here is the manual for your drill. Pictures show to install and remove the bit. http://powertool.manualsonline.com/manuals/mfg/makita/hr2450x.html
Apr 10, 2017 | Makita Drills
Makita hr1260 drill won't rotate. how can I fix it?
have an appliance centre check out the drill motor as it may be burnt out.
Apr 22, 2015 | Makita Drills
Change drill bit on makita dc18ra
on most you just push in the nose of the driver it will release
Jun 29, 2012 | Makita Lxfd01cw 18-Volt Compact...
My makita hr-385 is leaking grease from the bit
You don't say which part you brought for the HR3850k but if it is the Xring and O ring for the front of the tool cylinder you need to unscrew the tool holder from the cylinder and then just hook out the old seals and put the new ones in. This can very very tight and you will need a good vice to hold the machine. Can't remember if it is left or right hand thread.
Jun 08, 2012 | Drills
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Ive got a makita ZIC-26 hammer drill and the drill is stuck in and won't come out with the sleeve retracted. Is it possible to repair easily
if this is an SDS try grabbing the bit with some vice grips and jiggling it back and forth. DO Not do this when its plugged in or has a battery hooked up. (your model # did not mach an online search so I don't know what you've got. Also a bit of WD-40 or the like may help loosen it up.
Jul 24, 2011 | Makita Drills
Changing Bit
where the bit goes into the drill there is a metal ring. Pull the metal ring away from the drill with one hand and pull the bit out. this model you may have to pull the meteal ring twards the body of the drill.
Feb 26, 2010 | Makita 9.6v Cordless Impact Driver 6903VD
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
Drill bits do not lock in chuck or will not go in at all.
If the picture that I am seeing is of the same that you have then I can tell you that those are special bits that are fluted on the shanks so they can hammer. Also those drills do not chuck up like a regular drill. You have to pull the collar down insert the bit and rotate it until it falls in and then release the collar. Remember these bits are specific to the drill and can be hard to find, a rental store is a good place to find them for sale. Hope this helps. 2rns4u <*{{{>(
Apr 04, 2009 | Makita HR3000C Electric Rotary Hammer
Makita 12 Volt Cordless Drill/Driver Kit Logo
245 people viewed this question
Top Makita Drills Experts
John Trevino
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
