Question about RTO PasLode 900420 Impulse Framing Nailer
Whats wrong with my paslode?
My paslode will not fire upon pressing down
    Sniper:
  • 79 Answers
First, make sure you gas is not expired, it has a date on it. Next, Make sure your green light comes on. Does the fan come on when you press it down? Take off the back cover with the allen wrench and two phillips head screws on the sides. Pull it out, being very careful and make sure when you put it back the wires are tucked in there place again. There is an o-ring under the fan that may need replacing causing the vacuum to not work.Also, make sure the little spark plug is clean of all carbon residue. Clean with some WD40 or ether. Worst case scenario fan motor or spark plug. You can find parts for these things. Lemme know. Please rate me
Posted on Jun 18, 2009
My paslode im350 will only fire at 90 degrees and not in any other positions has any one got any ideas what the problem is?
You or who ever worked on your tool last didn't replace the lock out spring. I see this all the time. Its a little spring that holds the lock out down so the safety can engage. I bet when u try to fire the gun upside down the safety doesn't go all the way back.
Sep 13, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Have a paslode 350 it wont fire/ have spark, have new gas, fan works ,what could be wrong
The primary cause of a Paslode not firing is from a dirty combustion chamber. Try cleaning it with Paslode cleaner and as long as you have good fuel, good spark, and the fan works, it should fire.
May 25, 2014 | Air Tools & Compressors
Paslode 350 wont fire nail,gas new,fan works,have spark what to check next
My passlode 18 guage finnish nailer fires intermittently. Gas catridgev is good and battery is charged.it now only fires twice after it has been idle for a few minutes.Is this an easy fix?
This is awkward to diagnose. Sounds like a gas problem. Ensure the gas cell is in date. paslode print use by date on bottom. next ensure valve fitted to cell is correct normally yellow. When stopped firing press gas cell door (actuator) does it fire one more time? If yes it could be the actuator getting weak I have seen this cause similar problems to what you are experiencing.
Mar 30, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im65 does not fire unless you push push down twice for it to fire. have cleaned it around spark plug ect any ideas much appreciated
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Dec 12, 2010 | Craftsman Nailer Kit, Palm Air Driver
IM250 not firing.
heatman101
'l;l;
Apr 12, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I have paslode m/n 902000 does not fire when trigger is pulled its full of nails it never got jammed it started with sometimes not fireing to not fireing at all
Most Paslode problems start with the unit being dirty.
There should be some cleaning instructions that came with the unit. These instruction explain how to break down your paticular unit, and explains the cleaning process step by step.
You'll want to use Paslode cleaner, or if that's not available; use electrical contact cleaner.
Oct 28, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode gas nailer trim gun
there is no pendulum inside these guns it should work no matter what angle or upside down you are shooting it. If it is not retracting the piston trying cleaning the area and then lubricating really well that should do it if not repost and tell what that does.
Hope it helps you
Sep 23, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
Nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Jul 27, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
364 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
