Question about Troy Garden
Troy bilt mower and blades won't stay engaged
3 Suggested Answers
  • 205 Answers
SOURCE: Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Posted on Mar 21, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
I have a 3 yr old troy bilt riding mower when i engage the blade the motor dies. Any ideas?
Have you checked for any blade obstructions under the deck and with any moving parts keeping the blade from engaging?
Aug 03, 2017 | Troy Garden
I have a troy Bilt riding mower and When we turn pto on to engage it will engage but the noise is so loud. And the pto will not stay in the on position.
check and look at deck [ unit not running and key in pocket ] for loose ,damaged ,debris or out of alignment==belt ,pulley , mandrel,tention/actuator pulley or blades
May 04, 2017 | Troy Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Troy Bilt Kohler 18hp riding mower won't start.
there is a main fuse . usually hidden in the wiring . contact a dealer for assistance
Oct 07, 2017 | Troy Garden
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Gary
Sep 11, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
Troy Bilt 34073 mower - stripped spindle-shaft?
Bet on it- you might try adding an additional nut of the right size/thread or several washers to utilize the remaining healthy threads.
May 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
226 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
