Wireless mouse doesn't always work with HP Pavilion a1777c
Sometimes my wireless mouse and keyboard seems to have problems connecting to the receiver.  The blue light does not turn on even if it is plugged in and I refresh the red connect button.  This has happened with brand new batteries in it too.  What should I do?
  • juliannekapl Jun 16, 2009
    it is an optical mouse.....I don't think cleaning it is related to the connection with the wireless receiver, but I could be totally wrong.  I will have a look at it.
  • 43 Answers
Open up and clean the mouse
Posted on Jun 16, 2009
Hp touchsmart 300
From the User Guide at... http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4174137&
The wireless keyboard and mouse are pre-synchronized, for your convenience, to work with your
HP TouchSmart PC. The keyboard and mouse should work immediately after you pull the battery tabs to
activate the preinstalled batteries, and then turn on the mouse (A).
You may need to manually synchronize the wireless keyboard or mouse if they are not functioning.
To synchronize them:
Make sure the keyboard and mouse are next to the HP TouchSmart PC, within 30 cm (1 foot) and
away from interference from other devices.
Keyboard: Press the Connect button on the bottom of the keyboard (B) for five seconds. The blue
activity LED on the wireless receiver illuminates when the synchronization command has been received
and turns off when synchronization is complete.
Mouse: Press the Connect button on the bottom of the mouse (C) for five seconds. The blue activity
LED on the wireless receiver illuminates when the synchronization command has been received and
If this does not work, remove and then re-insert the wireless keyboard and mouse receiver from the back of
the computer and then synchronize the keyboard and mouse again.
Fr
Jun 30, 2014 | Computers & Internet
My hp optical wireless mouse is not communicating (compatible) with my hp620 laptop. The mouse is new. Regards, Wamnbugu Ngatiah Kenya
Hi, According to your problem first check the receiver battery and replace with a new battery. Keep the mouse within the range of the receiver. Connect the receiver with system, keep mouse within range and reboot the receiver and system both. If it doesn't solve your problem then go to the dealer or nearest service center for a replace.
May 06, 2011 | HP Wireless Optical Mouse
My keyboard and mouse on the laptop does not work. i am currently using a wireless mouse and keyboard
Sounds like your laptop keyboard and possibly the touchpad need to be replaced. You can order them through any authorized HP service center, or you can contact HP for out-of-warranty support if your laptop's warranty has expired.
Jan 23, 2010 | HP Pavilion dv6000z Notebook
I have an hp wireless mouse, and it doesn´t work!! Tried everything...
Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this could help you a lot..:-) Thanks..
Dec 27, 2009 | HP Wireless Optical Mouse
Hp wireless mouse not working
HP wireless mouse may not work due to improper connection of the receiver. If unknowingly you connect the receiver to a different port, then it may cause serious issue with HP wireless mouse.
If the connected port is corrupt and if the port is experiencing any problem, then the wireless mouse may not work properly.
In order to resolve this issue, you need to repair the port.
Get more information to fix HP Wireless Mouse Not Working . Hope this information helps you.
Oct 29, 2009 | HP Wireless Optical Mouse
Wireless keyboard not working
well,the problem is small,,first check with a different set of batteries on the keyboard,after tats done,press the connect button the wireless receiver and after 5 sec on the connect button on the keyboard,if the connection to the mouse gets disrupted then press the connect button on the mouse.the last step u can try changigng the usb port of the receiver,,,i beleive there is no other troubleshooting steps to this issue,,if still no go,,call up tech support and replace the whole set
best of luck,,keep me posted ,giv a good rating
May 19, 2009 | Computers & Internet
Keyboard and mouse not working
On the bottom of the mouse is a tiny little button that says connect or reconnect...press that to finish the connection process. Sometimes that very same little tiny button is on the bottom of the transmitter, look to see and press. You can best push the button with a pen or pencil.
Check to see that your batteries are in correctly also.
I hope this helps and does the trick for you.
Good luck and please leave a rating, thank you kindly...
Apr 26, 2009 | Computers & Internet
Hp Pavilion dv1000 laptop wireless connection doesnt always work? Sometimes it shows that a connection is available but it wont connect. Sometimes it works fine but drops out right in the middle of what...
you might have to review the driver version of your wireless. try to check if there are updates that might fixed the bug. go to my computer, right click, manage, device manager, network adapters - under it move your mouse on top of the wireless, right click, properties, driver and check driver version and date. then go to your hp pavilion product support http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=432999&taskId=135
and look for new version of network wireless driver might have. let me know if this doesnt fix the problem.
Apr 15, 2009 | HP Pavilion dv1000 Notebook
My mouse creative wireless is not working, i have the keyboard and the mouse. the keyboard is working but the mouse doesn´t. model WCU90D
sounds like you need to resync the mouse to the wireless receiver that is connected to the computer.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 01, 2009 | Creative Labs Creative Desktop Wireless...
HP Wireless Optical Mouse Fading
Ref wireless mouse. Not sure if you have a solution yet but it seems there could be 2 sources to the problem. First a weak or decaying laser. Second, something you have introduced recently that could interfere with the wireless signal eg mobile phone, another wireless device, cordless phone, telephone wires close to receiver or maybe something else. Not sure what you do if the laser is failing other than clean the lens. You might have to get it checked or try a friends mouse to see if it is better. There s also a setting than can change the sensitivity of the mouse. Have you looked at those settings.
Dec 10, 2007 | HP Wireless Optical Mouse
Computers & Internet Logo
62 people viewed this question
Alun Cox
David Payne
David Payne
