Question about Ryobi Garden
How do i remove Drum & Connector. I have a Ryobi bc30,RY30004d. i need to remove drum and connector so i can clean and inspect IGNITION MODULE ? also there is alot of oil everywere why is that? Thanks for this forum and any help. Regards Tobaz
  • 1 more comment
  • Tobaz Jun 17, 2009
    Taper i cant get to the ignition modual or even to the starter. there is a drum and clutch connector in front of it and cant remove plastic housing. thank
    Tobaz
    The drum and connector (clutch housing) is in front of the starter cord. That needs to come off first so i can get to the Ignition Module. Not sure how to remove the drum and connector...Thanks
    Tobaz
  • Tobaz Jun 18, 2009
    Thanks for your help Jim. Sorry i didnt alaberate more on this trimmer. i did some research and found out that this drum and connector is all one. and there is a screw inside that is part of drum and it is a star fitting. i bought a star wrench set and its a t25 size. came off.. sure enough ignition module was coated with oil. cleaned it all up and it runs great:) also i found out that if you dont run this trimmer at WOT then pressure will blow engine seals.... Hence all the oil....
    Thanks Jim for your help.
    Regards
    Tobaz
  • 1,041 Answers
When you say drum, I assume that you mean the flywheel. It doesn't need to be removed. There should be a screw holding the ignition module on. Just simply remove the screw.
As far as the oil goes, that's normal. Just clean it up a little.
Jim
Posted on Jun 16, 2009
  • 1 more comment
  • Jim Parker
    Jim Parker Jun 17, 2009
    Sorry, I'm not familiar with this situation then.
    Jim
  • Jim Parker
    Jim Parker Jun 20, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Sorry for the last post.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
How do I clean dryer squirrel cage?
To remove drum/fan drive motor:
• Remove rear panel & rear air duct. Remove belt from belttensioner. Remove top panel & drum if needed for better access.
• Disconnect terminal connector from motor, then remove two screws from motor mount & one screw holding fan to front shield. Lift rear of motor mount up and slide entire assembly toward rear of dryer.
• While holding motor shaft, not rotor fins, remove fan blade from motor shaft. Remove three screws, then remove fan housing from motor.
• Remove spring clamps by pushing ends of them down and away from motor. Lift motor up from motor mount.
Cage motor is the best blow out with compressed air. Also, by the way, clean the fan housing from the inside.
Dado
Nov 16, 2014 | Bosch Dryers
Error e03-51
E3- 51 Corona Wire cleaning 1. Cleaner Home Position Sensor 1 connector is
disconnected.
2. Cleaner Home Position Sensor 1 is defective.
3. Cleaner Home Position Sensor 2 connector is
disconnected.
4. Cleaner Home Position Sensor 2 is defective.
5. Cleaner Motor Drive Mechanism is defective.
6. Corona Mechanism is defective.
7. Cleaner Motor connector is disconnected.
8. Cleaner Motor is defective.
9. DRV PCB connector is disconnected.
10. DRV PCB is defective.
11. SPC PCB connector is disconnected.
12. SPC PCB is defective.
13. LVPS is defective
the corona unit is situated above the drum,in the drum casing and can easily be removed with 1 screw.
Sep 25, 2012 | Panasonic Workio DP-6010 Toner 35 000...
Bought new toner cartridge. Cannot figure out how to remove it from the printer. The 1 & 1/4 Hi X 9 inch door does not provide any handle or way to pull it out. Help. Bought new in Feb 2011
The drum and toner can become stuck in the machine if the develop joint link is not attached properly.
1. Open the front cover.
2. Remove the drum and toner.
- If you are able to remove the drum and toner, the issue is resolved.
- If you are unable to remove the drum and toner, continue to the next step.
3. Looking into the interior of the machine, there should be a plastic latch (develop joint link) on the left side of the machine that is connected to the front cover (connector), an inch left of the manual feed slot. This plastic latch is usually not the same color as the front and side cover.
- If the develop joint link (plastic latch) is there but not connected to the connector on the front cover, continue to STEP 4.
- If the develop joint link (plastic latch) or the connector on the front cover is broken, go to STEP 5.
4. Pull the end of the develop joint link (plastic latch) towards the connector on the front cover. If the develop joint link (plastic latch) pulls out, pull it gently to the left of the connector and then push it over the connector, securing it firmly onto the connector. Remove the drum and toner.
- If you are unable to remove the drum and toner or secure the develop joint link (plastic latch) onto the connector, continue to the next step.
5. Pull the end of the develop joint link (plastic latch) towards the connector on the front cover. Keep the latch pulled out and remove the drum and toner.
Aug 31, 2011 | Brother HL 2270DW Laser Printer
Access panel for fuel pump
There is none:
Fuel Tank & Fuel Pump Module Assembly Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Shift the vehicle into NEUTRAL and position it on a hoist.
  3. Release the fuel pressure.
  4. Disconnect the negative battery cable.
  5. Remove the fuel tank filler cap.
  6. Drain as much fuel from the tank as possible.
  7. Using suitable hose pinching pliers, clamp the fuel tank filler hose. Clamp the fuel tank filler hose in the location shown ford-05-00-396.gif
  8. Disconnect the three quick connect couplings from the fuel tank tubes at the tank.
  9. Disconnect the fuel pump electrical connector.
  10. Disconnect the fuel filter inlet tube from the filter.
  11. Position a suitable lifting device under the fuel tank.
  12. Remove the two fuel tank support strap bolts.
  13. Lower the fuel tank to access the fuel pump module while swinging the fuel tank support straps away from the tank.
  14. Clean the area around the fuel pump mounting flange.
  15. Disconnect the fuel pump module electrical connector and the fuel pump module fuel outlet tube.
  16. Using the special tool, turn the fuel pump module retaining ring counterclockwise and remove it. CAUTION
    The fuel pump module must be handled carefully to avoid damage to the float arm, filter and convolute hoses.
  17. Turn the fuel pump module counterclockwise and the fuel pump module will release from the locking tabs. Remove the fuel pump module from the fuel tank.
To Install:
  1. Install the fuel pump module in the fuel tank.
  2. Connect the fuel pump module electrical connector and the fuel pump module fuel outlet tube.
  3. Raise the tank into position and install the mounting strap bolts. Tighten the bolts to 26 ft-lbs (35 Nm).
  4. Connect the fuel lines and electrical connectors at the fuel tank.
  5. Lower the vehicle and refill the tank.
  6. Connect the negative battery cable.
  7. Turn the ignition key to the ON position to pressurize the fuel system.
  8. Visually inspect the fuel system for leaks.
Oct 05, 2010 | 2000 Ford Taurus
How do I change a fuel pump on a 2002 yukon
Need to know the size of the engine but this is a picture of what it is....
Posting the rest of the directions for you:
Illustrating fuel pump and sending unit sensor (3) on 2000-2004 4.8L, 5.3L, 6.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • Negative battery cable
  3. Relieve the fuel system pressure.
  4. Drain the fuel tank.
  5. Remove or disconnect the following:
    • Fuel tank
    WARNING Do not handle the fuel sender assembly by the fuel pipes. The amount of leverage generated by handling the fuel pipes could damage tool Joints.
  6. Disconnect the fuel and evaporative emission (EVAP) lines from the fuel tank module.
  • Fuel sender assembly retaining ring using a fuel tank sending unit wrench. Remove the fuel sender assembly and the seal. Discard the seal.
  • Note the position of the fuel strainer on the fuel sender. Support the fuel sender assembly with one hand and grasp the strainer with the other hand. Pull the strainer off the fuel sender. Discard the strainer after inspection. Inspect the strainer. Replace a contaminated strainer and clean the fuel tank.
  • Fuel pump electrical connector
  • Electrical connector retaining clip from the fuel level sensor
  • Sensor electrical connector from under the fuel sender cover
  • Fuel level sensor retaining clip
  • Squeeze the locking tangs and remove the fuel level sensor.
  • Remove the fuel pressure sensor.
  • To install:
    1. Install or connect the following:
      • Fuel pressure sensor
      • Fuel level sensor
      • Sensor retaining clip
      • Electrical connector to the fuel level sensor
      • Electrical connector retaining clip to the fuel level sensor
      NOTE Always install a new fuel strainer when replacing the fuel tank fuel pump module.
      • New fuel strainer in the same position as noted during disassembly. Push the strainer on the bottom of the fuel sender until the strainer is fully seated.
      • New seal on the fuel tank
      NOTE The fuel pump strainer must be in a horizontal position when the fuel sender is installed in the tank. When installing the fuel sender assembly, assure that the fuel pump strainer does not block full travel of the float arm.
      • Fuel sender assembly into the fuel tank
      • Fuel tank. Install the fuel tank strap attaching bolts. Tighten the bolts to 30 ft. lbs. (40 Nm).
    2. Refill the fuel tank. Install the fuel filler cap. Connect the negative battery cable.
    3. Turn the ignition ON for 2 seconds.
    4. Turn the ignition OFF for 10 seconds.
    5. Turn the ignition ON.
    6. Inspect for fuel leaks.
    Sep 13, 2010 | 2002 GMC Yukon Denali
    How to remove drum connector off ryobi weedeater
    I believe there are four phillips headed bolts around the outside edge of the housing
    Jul 23, 2009 | Ryobi Garden
    I have no spark on my bc30 trimmer. I have changed the sparkplug but still no spark
    You probably have a bad ignition module (coil).Or, you have a wire from the kill switch grounding the plug.
    Jim
    Jun 07, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
    Garden Logo
    251 people viewed this question
    Top Ryobi Garden Experts
    Jim Parker
    Jim Parker
    Rexter1
    Phil Walker
    Phil Walker
    Are you a Ryobi Garden Expert? Answer questions, earn points and help others
