Question about Whirlpool LER5636P Electric Dryer
I have a maytag legacy series dryer abt. 6 years old with moisture sensor. It stopped running. I checked the plug in (4 prong) and noticed that the black wire has burnt through and detached from the dryer. Should I try and get another four prong and reattach (I wld have to drill out the hole for the black wire attachment) or call someone? Also, was it attached right in the first place? (on the top: from L to R was black, white, red and on lower L was green). Thanks!
  • 2 more comments
  • jhlnewyork Jun 16, 2009
    I understand the idea of protecting the wires from heat but they came pre attached to a female adapter that the screw fit through and then secured down. My husband did the attaching about 8 months ago. Also, the hole where the screw goes into, is clogged with burnt debrie so I'd need to drill it out. Interestingly enough, for a while there, the dryer would work fine for a while and then would quit working. Now I think that was the wire burning out or a fuse blowing. Do dryers have internal fuses?
    When I pulled the cover off, that's when I noticed the black wire had burnt through. Funny that my husband didn't notice this before--but I'm the hands on person. Is there anyway to know that I'm attaching the wires in the correct configuration? Now, I don't even trust the way my husband hooked it up to begin with.
  • jhlnewyork Jun 17, 2009
    Thank you. Would they be able to provide the right screws also? I've now talked to my husband and he said that when he hooked it up the screws became lost if you dropped one when you were trying to screw in the tails. They would fall in between the housing of the dryer unit. So he had to use some other screws. Maybe the ones he used weren't the right thread causing the problem.
  • jhlnewyork Jun 18, 2009
    Okay, I bought the new power cord and detached everything. But now I have another problem? The heat from the fried wire, sealed the original screw hole. I was able to work this muck out using a tool but now realize that something behind this wire plate has also completely melted, well in half. I can slide the metal plate (that has the screw hold in it) up and first saw a bunch of "corrosion" and pushed that away and then half a circular piece came away. I'm wondering if that was a fuse and if I can just get a new one and put it back in (but I'm not sure what it was sitting on). or do I call defeat and call a repair person.
    Top Expert:
  • Whirlpool Master
  • 77,202 Answers
Replace the entire power lead for the dryer, u can buy them at most any hardware store for around $15.00, if the dryer had a serious issue the internal thermal fuse would have blown, also turn off the power to the dryer receptacle and pull the cover and check that for damage, if u are not comfortable with this type of electrical work and troubleshooting by all means call a service technician. REMEMBER ALWAYS TURN THE POWER OFF BEFORE DOING ANY WORK TO THE WALL PLUG..
Posted on Jun 16, 2009
  • 1 more comment
  • yadayada
    yadayada Jun 17, 2009
    I have hooked up many dryers and there has been a diagram inside all of them, but the hardware store person in a place like ACE can show/instruct u on proper orientation of the wiring connectors on the new plug/cable Assembly, forget Home Depot, no such help there, if u are not sure by all means please call a repairman.
  • yadayada
    they will be able to provide all u need as long as u have an example of the screw or know what u are looking for.
  • yadayada
    yadayada Jun 18, 2009
    sounds like the thermal limiter fuse, try replacing it, u will need to go to a whirlpool parts center or a good applience repair store for the part, can't help u there. You will need the exact model number of the dryer for the right part.
    Genius:
  • 1,341 Answers
You may need to replace the wire as you mentioned but be careful to have them replaced in the right color for color..By the sound of this it seems that heat which has caused this.So use some protective stuffs for the wire against heat..
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Maytag dryer stops after few minutes
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 21, 2015 | Maytag Dryers
Dryer is only 4 years old, was drying perfect one load, then the next its not drying. Takes 3-4 times to get load completely dry.
Feb 16, 2015 | Dryers
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Maytag legacy series washer leaking
Price is right. Repair time is right for an inexperienced repairman. Worth it ? If you watch what you are doing and not rush then, yes, it's worth it.
Jan 11, 2008 | Maytag Legacy Series Top Load Washer
Maytag Gas Dryer SDG515DAWW - heating stopped
if it dont come on in 30 secs replace it
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Maytag legacy series 3 yr's old
I had a similar problem where slowly specific buttons stop working. Moisture was getting into the control board and slowly killing buttons. I replaced the control board and that worked for another year, until the buttons began dying again.
For now, there are other ways to start the machine, but you just have to let time expire to stop it. It is probably a control board issue.
Dec 12, 2007 | Maytag MDB7100AWB Dishwasher
Whirlpool LER5636P Electric Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
