Epson Stylus CX6400 All-In-One InkJet Printer Logo
N
Neil Donald Posted on Apr 08, 2014
The ! Error message comes on and says to call service. Cannot get anything to happen?
Ho w do i get this error message off my screen
You have to enter the correct password to get rid of the error code.
Windows fails to start. nothing else happens it's like the computer is dead in the water
Are you getting any error messages? Is anything coming up on screen at all? Any lights coming on?
I am getting message service error 5100 and will
Hi You can Try 2 things.
Let us know if it works for you
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1helpful
2answers
When turning the power on to my Epson CX6400, the following error message comes up: "Error: Printer Error -> SEE YOUR DOCUMENTATION AND CALL SERVICE IF NECESSARY." The little "!" exclamation point...
Sounds like the ink counters need resetting (it happens with other printers as well)
Go here for more info as the prog supports your printer
http://www.ssclg.com/epsone.shtml
Lexmark t640 error message
"Remanufactured cartridges" How do you define that?
Given that Lexmark does not support or condone the use of third party products in their printers.
When a cartridge is new from the factory, all of the components inside the cartridge are new.
When Lexmark sell a recycled cartridge, all of the components within the cartridge are ETN components (Equivalent to new).
That means all of the rollers have been change and the PC is new.
It seems you purchased a cartridge which has a defect.
Return it to your point of sale and see what happens with the next one.
Don
Can't send or receive picture messages or download anything
In most cases, you need internet feature on your phone to use the picture messaging (MMS). In your case the free feature for internet should work fine. Keep in mind that you may be charged around $0.01 per kilobyte. The error you describe confirms the internet connection is not available and is causing the issue. This may simply be because the internet settings in your phone do not match the provider's settings. This happens when you buy an unlocked device. You will need to contact your provider to get the correct settings.
Lens Error
It is just telling you to try to turn the camera off and back on. This usually doesn't self correct and will need to be serviced. I would call Canon for support and see what the options are for service or upgrade.
Hope this helps!
Error 1304
Apparently some McAfee files are not gone, here lies your problem.
go here to Majorgeeks and download and run the McAfee
remover tool. . Let us know if this fixes your problem
http://www.majorgeeks.com/McAfee_Consumer_Product_Removal_Tool_d5420.html
481helpful
11answers
Error: Invalid Dim
this happened to me as well. i looked it up and heres what i found:
http://www.prenhall.com/divisions/esm/app/graphing/ti83/faq/faq.html
basically you have a stat plot on so to turn it off, press 2nd and then the Y= button to get to "Stat Plot"
one of them is turned on so press enter and select OFF. this should fix the problem!
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
