Question about Pioneer DEH-P460MP CD Player
Pioneer DEH-P460MP Won't Turn On
I needed a radio/CD player for my '95 Dakota (Sony Died). I work at an auto salvage yard and came across a Pioneer DEH-P460MP. It was in a wrecked Plymouth Breeze. Radio & CD worked fine. Brought it home. Same connectors as my Dakota. Hooked it up. Won't turn on. With key in "accesory" position meter shows power to the red wire. Nothing to the yellow wire. Does this radio have to have battery back-up to turn-on? Does it have a security code? Something else?
  • 2 more comments
  • bruss_lms Jun 16, 2009
    So, Are you saying that the stereo will not turn on if it does not have voltage to the yellow wire?
    Thanks!
  • bruss_lms Jun 17, 2009
    I understand that the yellow is for memory. What I don't know is if it will keep the radio from turning-on if there is no yellow voltage (some Kenwood radios are like this). Or, could it be that the radio being unplugged from power activated a sucurity condition where it won't turn on?
    That was it! I wired the yellow into the red and the radio works. I'll either have to trace the problem in my truck's wiring harness, or tap into a wire that's always hot. Anyway, you helped me figure it out.
    Thanks and regards!
    Yes, heeman 453 helped me figure it out.
    Genius:
  • 1,341 Answers
What I normally do in these situation I put orange with red and connect it to while I put a negative ground to the body of the cd player.Then it should power up if nothing else is stopping it.Also check the fuse at the back of the radio.Remember the orange wire I think is for permanent electric supply to store radio stations and settings..Any question then feel free to ask.I hope this helps.
Posted on Jun 17, 2009
  • 314 Answers
The yellow wire keeps a constant voltage going to the stereo at all times. This is the wire that keeps stereo memory. What you should do is to trace the circuit (this wire) all the way back probing with your positive lead on your meter and then see at what point in the circuit that it does not have voltage and base your repairs on that. I really cannot give you an accurate diagnosis without actually knowing where the wire is not getting voltage
Posted on Jun 16, 2009
CD player for my auto
resetting time means?
u want to reset the worked hours or reset the player to defaults?
Dec 30, 2007 | Pioneer DEH-1900MP CD Player
Need the owners manual for Pioneer DEH-P3700MP
I can scan and e-mail any pages you may need.
Nov 01, 2009 | Pioneer DEH-P3700MP CD Player
No sound from Pioneer DEH-P4600MP unit? Everything powers up and function,wires are installed correctly.
check the speakers to see if they work. also check if the vehicle has an amplifier. if still no sound try to connect the radio directly with a speaker in the back with the wires that come with the radio. sometimes when one of the speakers in the vehicle is shorted out it will not sound. if you have tried all of the above and still no sound you might have a bad (ic) intergrated circuit. it is located on the back end of the radio. the aluminum piece is bolted on to it. just look where two bolts are at least an inch apart almost in the middle. the ic# is pal007a. that can be replaced with different model numbers like tda 7384 and so on.
Sep 22, 2009 | Pioneer DEH-P460MP CD Player
NEED A WIRING DIAGRAM FOR A PIONEER DEH-1800
yellow- 12volt
red- Ignition
black- ground
blue/white- remote (amp turn-on)
white and white/black- front left
gray and gray/black- front right
green and green/black- rear left
purple and purple/black- rear right
Black stripes are negative.
Aug 07, 2009 | Pioneer DEH-1800 CD Player
Need to wire it into dodge dakota
you will have to check with a radio dealer to get the correct "pigtail" to install that into your Dakota..and also the dealer can tell you if it is compatable with your Dakota..i hope this helps
Apr 26, 2009 | Pioneer DEH-3400 CD Player
How do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Dec 27, 2008 | Pioneer DEH-P7600MP CD Player
My Pioneer DEH P20 doesn't turn on any more
It sounds like they blew the line fuse on the wiring harness. this is on the wiring that connects the radio to your car's wiring (not in your fuse box).
Oct 15, 2007 | Pioneer DEH-P2000 CD Player
Can't locate aux function
Try turning the unit off first - Pioneer manuals are notorious for mentioning this at the beginning of the section, which doesn't really help if you skip to the part that you are interested in.
Nov 12, 2006 | Pioneer DEH-P460MP CD Player
Pioneer DEH-P460MP CD Player Logo
129 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
