I have a black filter over my picture which does not let me see my picture clearly.
    President:
  • 2,992 Answers
You may have closed-captioning turned on and set for "text" mode. Check your settings and be sure it's turned off. Many remote controls have a single button to control captioning and it's easy to set text mode without knowing it. Then the set puts up an area for text to be displayed, but there isn't anything to put there. On channels where captions aren't being used you don't see any problems, but on others you'll see the box on the screen.
Posted on Jun 16, 2009
Tv come on but cant clear the picture from turning red and black how can I get a clear picture?
Without knowing anything about your Tv make or model this is hard; but there should be a reset button in your menues to restore all settings to factory default. Find and use that. However I am suspicious and think the set needs reapir.
Jan 02, 2015 | Televison & Video
Black ice
My advice throw the dirty ice away then monitor. It could be residue from old filter or even new. This happens sometimes and usually clears it self.
Apr 19, 2013 | U-Line ULine Origins Series Ice Maker 25lb...
Picture not clear, mostly black.
Well you most likely will need a technician or if you have technical ability........the Y sus board which operates the drivers of the plasma screen.........in some instances it will need both the y sus and the z sus boards.........the repair could range between $300 and $500 . be sure to go to an LG auth service. If you would like assistance on how to repair your self,let me know!!
Jun 02, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Dyson animal is giving me fits
Try this quick repair and see if this fixes your Dyson in terms of not going in the upright position: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it. The suction problem is happening because when the machine is put in the upright position it diverts the suction from the floor to the hose automatically, and it's probably stuck in between the lower part and the hose part.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    In terms of the machine not picking up, this could be caused by a few things.
    The first thing you should check is the filter. The DC14 has a motor filter that is recommended to be washed every 90 days. Here's how to access this filter:
    • To remove the washable filter: Remove the clear bin; and cyclone top from your machine by pressing the cyclone release button.
    • Lift clip to remove the filter from the machine.*
    *The post-motor filter located under the clear bin should last the lifetime of the machine and does not need to be washed.
    There are two different types of filters that were used on the Dyson DC14, and One part filter, and a two part filter. Here's instructions on how to clean both of them:
    ONE PART FILTER:
    • Wash the filter in cold water only. (Please do not use detergent, do not wash in a dishwasher or washing machine).
    • Repeat the steps shown below until the water runs clear.
    • Leave to dry in a warm place for 24 hours. DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    • Please ensure the filter and filter case are completely dry before refitting into the machine.
    1_part_filter_drying.jpg TWO PART FILTER:
    • Wash the filter in cold water only. Please DO NOT use detergent on the filter, or wash the filter in a dishwasher or in a washing machine.
    • Leave the filter to dry in a warm place for 12 hours, until completely dry.
    • DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame.
    The filter should be washed at least once every 6 months.
    Also, since you have removed the bottom plate, a common problem on the Dyson's is when this plate is reinstalled. It is very easy to put the plate on incorrectly, which prevents the brushes from hitting the carpeting. This can seriously decrease the pick up on carpets. Check the bottom plate to make sure that it was put back on properly. Here's pictures of both the correct, and incorrect way to reinstall the bottom plate:
    Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
    Here's another picture, that is the RIGHT way to install the soleplate:
    I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    May 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
    It does not shows clear picture
    turn the black ring that is around the len's while your cam is on and you can see a picture. ...the black ring will focus your lens. turn till you get a clear picture...turn either one way or the other till picture clears up
    Aug 30, 2009 | HP USB Web Camera
    Vertical lines showing in picture, especially noticable on black
    in these issue you can see vertical lines due to filter capacitors bad in the secondary power supply. 100micfarad/j35volts, 220microfarad/25volts.
    Jun 09, 2009 | Mitsubishi WD-52725 52". Rear Projection...
    IC POWER CM2017 LCD MONITOR
    Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
    A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
    Jun 24, 2008 | Gateway FPD2275W LCD Monitor
    Camera will take picture, but the picture is coming out black!!!! Help Please!!!
    Dear vera11:
    The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
    First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
    If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
    If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
    Hope this helps.
    Sincerely,
    HeavyDLB
    Jun 01, 2008 | Canon PowerShot A520 Digital Camera
    Televison & Video Logo
    23 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
