Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore side by side cold spot 4 years old just stopped cooling and freezing
  • kmorm Jun 17, 2009
    106.54502300. is the model number inside the fridge.
  • Kenmore Master
  • 4,655 Answers
Defrost problem is possibly the reason. I need to know the model number for example 213.25897 would be a way that Sears identifies their appliances. Let me know which model and we will go from there. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Posted on Jun 16, 2009
  • John Tripp
    John Tripp Jun 17, 2009
    Your refrigerator has a defrost timer inside the control panel in the fresh food section that tells your refrigerator to defrost every 10 hours. If defective the frost will accumulate on the evaporator coil inside freezer and behind the back panel of the freezer to become frozen over. (There is a movie posted on my site that refers to a frozen evaporator) So I need you to find a small opening inside the control panel and place a small flathead screwdriver into the hole and turn the timer slowly clockwise until the compressor stops running. When it stops running this should be the defrost section in the timer and after a minute you will possibly hear a sizzling and cracking noise inside the freezer area. That is the defrost heater melting the frozen over evaporator. Leave the timer in this area for 20 to 30 minutes until the refrigerator comes back on. If it does not come on then simply turn the timer again to the right and that will begin the cooling cycle.
    Defrost Timer Kit
    P/N: 482493
    I tried to upload the photo of control panel but it may have been too large to post here. I will post a photo of that later in the day at my site. Go to site below if this is the part causing the problem and enter it into the parts search feature on the top of page. That will take you to the replacement photo. Let me know how things go. Thanks, Sea Breeze (click on link below)
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
check to make sure that there is no ice build up in the went in the freezer, best way to fix is to shut off fridge for about 8 hours to defrost and then plug back in, this will help the fridge start cooling again.
Jun 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Will not cool proper on fridge side
THIS IS A DEFROST PROBLEM EITHER THE THERMOSTAT OR DEFROST TIMER IS BAD! THE THERMOSTAT IS LOCATED BEHIND THE WALL IN THE FREEZER COMPARTMENT ATTACHED TO THE COILS TO KNOW IF ITS BAD IF WILL HAVE A RAISED SPOT ON THE BACK LIKE ITS BUSTING OPEN CHECK THAT
Apr 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not cooling
did you unplug it for about 8 hours to make sure that it is completely defrosted? These new side by sides use cold air to cool them unlike the good old freon tubes running aroung the inside like the fridge your grandmother had for 50 years. They freeze up easy and take for ever to thaw out. check the seal around the bottom of the door to make sure it is not broken or hanging loose.
Mar 05, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
407 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
