Question about Samsung 206BW Monitor
Samsung syncmaster 206bw turning on and of, light flashes on for 4 seconds, then off for 2 repeatedly i can see windows is working fine in the background during the 4 second gaps while the monitor is on have tried the analog cable to hook up to pc as well as the other 1, also reseated the graphics card, and left both pc and monitor unplugged for a few minutes
  • gr0undzero Jun 19, 2009
    not an option unfortunately, it would invalidate the warantee
    was hopeing for a hold power button while pressing some other one kinda fix :p
  • 3 Answers
If you have soldering iron and can place an order at DigiKey.com (and are willing to get your hands down on this), this is a rather easy fix with some direction. You basically will be replacing some failing capacitors inside the unit.
Posted on Jun 18, 2009
  • GFBusiness
    GFBusiness Jun 19, 2009
    Process the RMA then.It is a power supply/inverter problem.
    Scholar:
  • 137 Answers
For full details on how to fix this fault check out my samsung 206 page:- http://www.normsweb.com/tektips/sam206bw.shtml
Posted on Oct 01, 2010
  • 3 Answers
First, it is good to see others have had this issue. I have had my monitor going on two years or so. In the last two months, turning it on it takes longer and longer for it to 'warm up' before it stays on. I also have the blinking on and off with the desktop and functions working fine underneath. Today it took about two hours. It went on fast when I used a hair dryer to warm it up through the air flow holes on back/top of the monitor. Within 30 seconds, it flipped on. So, I'm hearing that a it's a power supply issue/inverter. Interesting. I am going to do a bit more research before I take it apart. It would be good to know if others have a problem? and, other solutions?
Craig
Wichita, KS
Posted on Jan 25, 2010
  • Warf135
    Warf135 Oct 01, 2010
    for full details on how to fix this fault check out my samsung 206 page:- http://www.normsweb.com/tektips/sam206bw...
I had the same problem and i left my monitor turned on for about 10 min and it keeped turned on but it say no signal so i just reseted it and it's workng perfectly now, so try to keep it turned on and just maybe it will work
Posted on Aug 08, 2010
My Samsung Syncmaster 2033SN LCD Display flashes after every 5 seconds
Get in touch with Samsung support: http://www.samsung.com/us/support/contact
May 19, 2015 | Samsung Computers & Internet
My samsung 940b it has a clear bright screen ( as normal ) just for 2 seconds then the screen turns dark but you can see very very dim Window logo.Turn off the power ( does not matter for how long ) when...
Shine a flash light onto the monitor, if you can see icons/desktopon the screen then you know you need a new monitor!
You should be covered under warranty!
Mar 02, 2011 | Samsung SyncMaster 940B Monitor
SYNCMASTER 206BW PROBLEMS I started having the same problem about 2 weeks ago. The screen flickers on and off for about 15 minutes. Although I can see windows is running in the background, the screen...
Common problem with just about 905 of failed LCD monitors; bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 26, 2010 | Samsung 206BW Monitor
931B tries to come on but shuts back off
Problem solved by changing 3 capacitors (C112, C113, C316).
Replace the 470uF 25V with a good quality low ESR type and the two 820uF 25V with 1000uF 25V low ESR types.
The 1000uF caps should be 10x20 in size, however I managed to get 13x20 caps in, but it was a bit tight.
Apr 03, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Samsung 206bw Monitor Flashes/Flickers on and off
Set the Hrts to 60 in Display Properties in control panel
Jan 14, 2009 | Samsung 206BW Monitor
Window screen problem
I'm guessing you may need to download the proper software and drivers for this monitor. Have you always had this problem and now want to change it? Try this website: http://static.tigerdirect.com/pdf/samsung-206bw-manual.pdf
Jun 21, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 206BW Monitor Logo
5,175 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
