Question about Kenmore Dishwashers
My Kenmore Ultra Wash dishwasher needs the trap cleaned. How do I do this? I do not have a manual. The model number is 665.16362301
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Posted on Feb 08, 2008
IFIXALL
  • 868 Answers
SOURCE: Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
Posted on May 21, 2008
SOURCE: Kenmore Ultra Wash Quiet Guard
there is a hose right on the back? its not rocket science!
Posted on Jun 05, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore ultra wash dishwasher model number 665.158.5090
the only way you can tell if the upper rack is not getting enough water is to turn a glass right side up in each corner. then run for 2 minutes and see if there is water in each cup.
if you still dont get water, then you have checked the pump, the only thing left is that you are not getting enough water into the unit.
start the d/w at a normal cycle, let it fill and go into the wash cycle, takes about 3 minutes, then check to see if the water level is just below the heating element. if so then it has to be the wash pump being plugged.
if not enough water then you should change the water inlet valve. some times they do get plugged but also make sure you are getting full water pressure to the unit as that could cause not enough water into unit. the faucet under sink could be at fault i have seen valve work but not let enough water in, so dont be surprised if you need a new valve.
Posted on Jan 06, 2009
Do you have access to the reset code for my Kenmore Ultra Wash dishwasher model 655.16812990?
Check your model number again. Missing or transposed numbers. You should be able to see or download rhe manual here. Also parts and diagrams.
Parts for Brands Craftsman GE Kenmore Whirlpool and more
Sep 04, 2014 | Kenmore Dishwashers
Kenmore ultra wash model 15951793 sani wash flashing
what is your model number is then we can get started then
Jan 04, 2013 | Kenmore 24 in. 16032 Built-in Dishwasher
Need a owners manual for a ultra wash II dish washer model # 1581591
Is this the correct dishwasher?
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-6651581591/0582/0130000?searchedModel=1581591&blt=
Feb 01, 2011 | Kenmore Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Dishwasher that leaves dishes dirty
Your drain could be blocked, remove the drain from the trap below the sink and try running the unit on drain, into a bucket. Also check the connection at the trap to ensure it is free from blockage
Mar 19, 2009 | Dishwashers
Older dishwasher-kenmore ultra wash. Serial no ff3902085, model no :110764511. I have no info on how to run it. Does it take rinse agent? D. Wickes
Hi landwix,
I'm Harvey the Master Plumber.
Your problem is: older dishwasher-kenmore ultra wash. Serial no ff3902085, model no :110764511. You have no info on how to run it. Does it take rinse agent?
Operation is simple and yes it will take rinse agent if you so desire. Rinse agent can be purchased either liquid, dry or combined with the soap in a tablet (I don't recomend). The dry comes in a tiny basket you hang from the upper rack. The liquid goes in the dispencer next to the soap dispencer. Just twist the plug counter clockwize about 1/4 turn and lift out, pour in no more than 4 oz. slowly and replace plug. Forget about it for a month. It will use a few drops with each use. Fill soap dispencer about half full and close. Choose wash cycle (normal, etc.) then press start. Thats it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 21, 2008 | Dishwashers
Kenmore Ultra Wash #15779
Probably would need the full model number but it looks like you control board is defective.
Sep 02, 2008 | Kenmore 15899 Built-in Dishwasher
May 20, 2008 | Dishwashers
Dishwashers Logo
157 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
