Question about Ricoh Aficio BP20N Laser Printer
Printer not printing. Online/Error is blinking orange light. How do I get printer to work again?
    President:
  • Ricoh Master
  • 1,447 Answers
What is the brand your printer
brother -change toner
Posted on Jun 17, 2009
Status light blinks orange
Unfortunately, if the Status light is blinking Red, the printer is reporting an internal failure. Try turning off the printer and then turning it back on after a few seconds. Another reset to try: unplug the power cord from the printer and from the wall outlet. Also remove the USB cable from the printer and computer. Wait a few minutes and then reconnect the power cord. Turn on the printer (if it doesn't turn on again). Then check the error light. If it doesn't recur, plug in the USB cable (printer and computer). You may want to try a new USB cable or a different USB port on the computer. Try printing again.
If the error repeats, you will need to contact Brother if the printer is under warranty or your service provider if you have a contract covering the unit. If the printer is out of the warranty period, decide if it is worth the effort to get a diagnosis and repair.
I hope this helps.
May 11, 2013 | Brother DCP-8060 Laser Printer
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
My computer doesn't send picture to be printed to my hp photosmart 8450. I have Windows Vista and it worked before. Now why does it show an error in the printer info and also, this printer is set as...
If there is something wrong with the printer, you should get a error message describing the error.
Does the printer have a blinking orange light after you give the print command? Then there is an error in the printer. If you have documents in the print queue, delete them. Remove the printer cable. Shut the printer down, shut the computer down. Reconnect the cable and turn everything on again.
If there is still a problem there might be something wrong with your printer.
If you don't have a blinking light after the print command on the printer, then try changing the printer cable. If not working, try another USB port. If still not working, reinstall the printer.
Sep 21, 2010 | Dell Office Equipment & Supplies
Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Oct 29, 2009 | Canon BubbleJet i560 InkJet Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
HP Deskjet F4180 colour lights flashing and printer offline
Hi I have exactly the same problem, and can't scan or make copies. I went to HP Online, and tried their advice, which didn't work. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&lc=en&dlc=en&cc=us&product=3177566&rule=25623〈=enHP's solution made me realise it might be a scanner problem. I made a wild guess and kept the cover above the glass panel open. Turn off your printer, lift the cover up and turn on again. The lights should stop blinking and you should be able to scan/copy/print. I guess the cover prohibits the device to scan properly causing the blinking lights. Hope this helps!
Jul 01, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
I get a message error that ink cartridge is not well installed
Remove all the cartridges then back again installed..if the orange light is always blinking.long press the cancel botton til the green light is steady..ok..
Jan 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Operator Error Canon i850 printer
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
Gives the error for ink tank full
Before you try to reset your Canon i9100 be sure to remove the ink head itself before attempting and then replace after, it won't work if you don't, I almost threw away 2 good printers before I read this today.
Jan 24, 2008 | Canon i9100 InkJet Photo Printer
Ricoh Aficio BP20N Laser Printer Logo
378 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
