Question about Husqvarna Viking 1
Thread breaking with my MegaQuilter,
The problem I have more than anything else is top thread breaking every 6 - 8 stiches. I use HLx5 needles, size 14, I keep it clean under the dogs. try to keep fresh thread, tried different kinds of thread. from what I have read, the lower the # on the thread..the higher # of needle.
thread at 40 wt or less need 16 or 18 needle. my thread is Superior so-fine 50 wt. I am trying to use a 14. This machine is never constant, sometimes it works fine, most times the thread breaks
  • floridamae Nov 18, 2009
    I purchase a Husq varna Viking mega quilter 18x8 this summer.
    My concern is the thread, it come out of the needle after several stitched. Has anyone experience this situation and solve the issue?
    Problem Solver:
  • 6 Answers
The problem you describes sounds like it maybe caused by a burr along the thread path. Does the thread shred or does it appear to be cut? Does this only happen with so fine or with other threads as well? Take your finger or if that doeswork use a cotton ball, along the thread path, you are looking for a sharp spot that will be causing your thread to shred. Change you needle for a new one, Make sure you put it in the correct way. Also if these don't do the trick hand wheel the needle up and down a few times. make sure that there isn't a burr in the throat plate from a broken needle and observe near the bobbin case and timing finger that the needle isn't rubbing against something( you might want to use a magnifing glass). i hope this helps. I know how frustrating it can be .
Posted on Jun 24, 2009
    Problem Solver:
  • 6 Answers
The brand of thread I use in my Viking is Mettler or Gutterman. It does not work well with any other type. When I have all but thrown in the towel I begin back at the manual and it usually has a solution.
Posted on Jun 18, 2009
The top tread breaks after about 1inch when trying to do chain stich on my janome cover stich machine
Could be the result of several things. There could be some gunk or threads stuck in the tension disk. Be sure to remove the thread and rethread from the beginning in the order specified. ALWAYS RAISE the presser foot when threading!!!! If you haven't tried a brand new needle, do so, and make sure it is pushed all the way up and installed with the flat side facing the correct direction. Some machines recommend #90 as the largest needle to use. Also, perhaps the needle eye is too small to accommodate the thread. Watch where the thread is breaking to give you an idea of where the problem may originate. Try a different brand of thread. Sometimes black thread causes issues because the heavy dye affects the thread. Set the tensions at the midway point and then loosen the tension on that one needle. There could also be a burr or rough spot somewhere along the threadpath that is catching the thread. Last idea--could be a timing issue.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Make It Handmade Threading Your Serger or Overlocker
Help please Serger needle thread breaking
Sewing Machine Thread Keeps Breaking
Dec 08, 2016 | Janome Sewing Machines
Singer 7470 computerised sweing machine is breaking top thread every after1-2 feet stiches plz suggest me wt to do top gthread is not too tight , i cleared all the lint in the bobbin thread is gd qlt
The needle thread breaks
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3.the needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and the bobbin thread are not set under the presser foot when starting sewing
6. The threads were not drawn to the rear after sewing
7. The thread is either too heavy or too fine for the needle
Jun 15, 2015 | Singer Sewing Machines
Top thread is breaking on Janome 6600P
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 16, 2013 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Oct 08, 2012 | Juki Sewing Machines
Brother 920d breaks the thread shortly after a few stiches
Mar 03, 2012 | Brother Sewing Machines
When I am sewing it will sew about 3 stiches and then jam.. It does it if I change weight of material or it will s kip stiches.
Skipped stitches is usually indication that needle is blunt or burred.
Or if you are using a sharp needle on knit fabrics it may also skip a little.
Not sure what you mean by "change weight of material" - do you mean you are sewing applique and going from one fabric weight onto another? or different sewing projects?
It is a good idea to change your needle for each new project (4-6 hours sewing time max) and choose the right type of needle and size for your project.
However, the jamming part sounds more like thread tension issues, especially if the jamming is happening underneath from the bobbin. If stitching is loose underneath, then top tension is the problem and visa versa.
Recheck your threading path, top and bottom tensions and that you have good quality thread. Change the needle, rewind a fresh bobbin, thread up and try again.
There is really good info on www.sewing.about.com or I refer to my Singer Sewing Machine textbook at lot too. Good luck.
Mar 30, 2011 | White Sewing Sewing Machines
I am sewing a quilt and my needle is in the right place but it keeps breaking. Please help. Also, the thread break often.
here are something you might check
upper thread breaks
1.top tension to tight
2.thread to thick or to fine for needle
3.needle not inserted correctly
4.thread caught on something-spool pin, tension area
5.needle damaged
6.needle thread is not threaded properly
Needle breaks
wrong size needle for fabric
also check for lint & pieces of broke needle under the needle plate
also the bobbin case area -take the bobbin & case out & check for pieces of broke needle
here is a tip about needle & thread
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 21, 2010 | Husqvarna Designer I
I am using black bobbin threaad with white needle
In my experience, I can adjust the tension on my older machines (like my Singer Featherweights so that the needle thread will not show at all on the underside of the fabric (and the bobbin thread will not show at all on the top)--but I've found it nearly impossible to get the same degree of control on my newer (computerized) machines. It always seems that there is a touch of the needle thread showing on the bottom and a touch of the bobbin thread showing on top.
I'm not familiar with the MegaQuilter but I'd just keep playing with your tension control to get it as fine as possible.
Robbie
Aug 01, 2010 | Husqvarna Viking 1
The top needle unthreads after just a few stiches. I have a Singer 2950 and am new to sewing.
Are you saying that the thread is breaking?
CAUSES of upper thread breaking
needle is in backwards
improperly threaded
tension to tight
needle bent or blunt
thread to coarse for size of needle
needle too long for machine
burr on needle
tension discs worn so that thread works in grove
neele too fine for size of thread and fabric
lint or dirt around bobbin case holder
irregular sewing speed
AND THE BIGGEST PROBLEM IS:
threads not properly pulled back under pressure foot when starting to sew
This means, Have enough of the upper and lower thread pulled to the back and hold for the first 2-3 stiches,
Do this every time and it will become second nature and you will do it automatically
Aug 28, 2009 | Singer 2950 Mechanical Sewing Machine
MegaQuilter Tension
Try at least 2 new needles first (HLX5, preferably Schmetz). If same, look for any rough edges on the needle plate and feed dog cover.
Beyond that, this does not sound like you are doing anything wrong. You should take your machine in for adjustment by an authorized technician. You should have about 1/2 to 1 full turn of the upper tension knob between too loose/ugly on back and too tight/breaking on the top.
May 10, 2009 | Husqvarna Viking 1
Sewing Machines Logo
442 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
