Question about Directed Dei Valet 561r Remote Start/Keyless Entry
Vehicle lost fire
I have a 98 nissan maxima and the car lost fire. I took it to a mechanic and everything checks out fine. Is there a byhpass i could try on a Valet 561R remote start. There is not a valet switch installed and could this system really cause this problem ?
    Top Expert:
  • Directed Master
  • 82,322 Answers
The security system doesn't disable spark, it works by not letting the fuel pump run or not allowing the starter to work, but never does it affect spark or fire as you call it.
Posted on Jun 16, 2009
    New Friend:
I have a vw cabrio is doing same thing try to stick your key in driver door see if fuel pump kicks on
Posted on Mar 21, 2014
Any good website for Wiring diagram of nissan car maxima 1999?
Get one of the Hobbs or hanes mechanic books for your year and make of vehicle. It's got everything inside .
Mar 02, 2018 | Nissan Cars & Trucks
'89 Nissan Maxima runs and drives but gets no power when accelerating.
Given everything you have already done to it I would suggest checking for a faulty distributor or coil. Have you checked the timing? I had almost the exact problem in a previous vehicle and it ended up that the top of the coil wire was arching onto the exaust manifold intead of firing the cylinders. I found this out by having someone rev the engine while I inspected all the plug wires and coil wire for external sparks. Good Luck keep me posted.
Jun 30, 2012 | 1989 Nissan Maxima
I took front coils on 2000 Nissan maxima and #6 didnt fire like 2 an 4
Take the number 2 and put it in place of 6. If that 6 fire then your solution is a new coil. If it still doesnt fire you have a control issue and the pcm will need to be addressed
Feb 22, 2012 | 2000 Nissan Maxima
Hi, i have a 1992 Nissan Maxima with a 3.0 v6. It was running like a champ, and then i took it to a car wash and sprayed the engine down. After that the car started to miss, backfire, and lose power. Were...
Just speaking from prior experience on this one. If the engine was very hot and it was hosed down with cold water, then it could be likely that you possibly cracked the head and it is sucking air into the cylinder's during the firing process which too much air and fuel mixing when the spark plug fires causes a misfire. Take the vehicle to a respectable mechanic and tell them exactly what happened and they'll take care of the rest.
Dec 28, 2010 | Nissan Maxima Cars & Trucks
2000 nissan maxima cranks but wont start most of the time
fire your mechanic its just a bad relay. most likely the fuel pump relay or a ground wire is loose. now pay me
Nov 20, 2009 | 1995 Nissan Maxima
2001 Nissan Maxima loses power at 40 MPH.
Fuel pump is not pumping hard enough anymore. Have a mechanic check the pressure. Either pump is bad or the fuels filter is clogged. One other thing that causes this is a clogged Calalytic Converter.
Oct 27, 2017 | 2001 Nissan Maxima
Flickering Lights
You do need an alternator. Nissan has a campaign on Maxima alternator in certain years such as 96-98 I believe. Go to your friendly Nissan dealer abd have them punch your VIN number into the NNA net. they will know and that will tell them if your vehicle applies by the VIN. I have seen the alternator on fire. There was fire inside of the alternator. Have it checked or the car can catch on fire.
Dec 23, 2008 | 1997 Nissan Maxima
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
290 people viewed this question
Top Directed Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
