Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer stopped working
The freezer seems to work for a while then goes into a defrost cycle for days at a time. It's only 5yrs old.
  • 15,935 Answers
Your defrost timer has failed.
If ABB1927DE is the proper model # - please find the timer HERE and note it is integrated on the controller board - so it must be replaced as a unit.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 16, 2009
I have a problem with my s75438dt,the fridge as stopped working
If defrost heaters in freezer stop operating during defrost cycle, ice builds up around coils and blocks cool air from being blown to refrigerator side. If ice you need to defrost with heat and replace heaters. Remove rear freezer wall and look for solid ice covering coils. Also push freezer door switch closed while keeping door open and determine if fan is working.
Feb 06, 2016 | Refrigerators
Prep table is not cooling, fan is working, unpluged it for a half hour or so and seems to be working again but will probably stop working again, this is the second time it has happened in the last few...
Michael Youngman
Expert
Sounds like your defrost cycle has failed. Your defrost cycle is operated by a defrost timer or your motherboard depending on the age of your refrigerator. When your refrigerator goes into defrost, it turns on an electric heater that melts the ice from your coil in the freezer. When your defrost time or electric heater fails, it allows ice to build up on the coil in your freezer which blocks airflow which causes your cooling compartments to not maintain temperature. Hope this gives you an idea what to look for and a guide on where to start looking
Jan 21, 2018 | Carrier Beverage Air® SP72-18
Frezzer is only 2 yrs old and already has defrosted on its own what seems to cause that?
This machine has an automatic defrost cycle that comes on automatically 4 times a day. During defrost the compressor goes off and the heaters inside come on and melt the frost from the coils. In about 20 minutes heat shuts off and compressor comes back on and freezes againl
Oct 18, 2010 | Continental Freezer Freezer display one...
Fridge stops working and warms up for half a day then will cool back off and start working for a day or a few days. When it warms up everything in the freezer defrosts but will then refreeze a day later...
Check your defrost thermostat in your freezer access panel. Your defrost timer could be faulty, Your defrost timers ussually run for 12 hours and defrost runs for 30 minutes. That being said that is why I believe your timer is getting stuck on run and then eventually it finally gets unstuck and goes into defrost. Eventually it will get stuck in one place or another.
Aug 27, 2010 | Frigidaire FRS26H5AS Side by Side...
Hi . My questionis: Ive got a freezer /
probably defrost problem check for ice behind panel where fan at. defrost t-stat bad is most common
Oct 27, 2009 | Bosch Refrigerators
Fridge not cold as should be
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 29, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Both freezer and refrigerator temp variations
in most refridgerator cabins is a air dam at top right of side by side and it could be sticking open and working other times or it could get stuck in defrost cycle due to defrost timer not working properly.defrost timer would be first thing to look to.
Apr 20, 2009 | Refrigerators
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Freezer won't start after defrost cycle
It might be the timer motor, if it doesn't run. neither does the timer. Easily replaceable and cheap. good luck. John
Nov 07, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Defrost issue
its the timer if you manually advance it and it heats the back of the freezer please rate my advice...
Oct 02, 2007 | Kenmore 71279 Bottom Freezer Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
210 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
