Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Yellow light in power button comes on but tower not will come on ???
  • Dell Master
  • 1,684 Answers
Check power cables first, then replace power supply in pc if it still will not power up.
Posted on Jun 17, 2009
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
The start button twinkle on the tower
have the internal power supply examined for bad caps or missing voltages.
Jun 10, 2012 | HEWLETT-PACKARD Hp Fm049ut Workstation - 1...
My Desktop will not power on! When I press the power button it turns yellow but wont come on. If I press and hold power button, the yellow light goes out and a green light in the rear of the tower...
Please click this link Dimension 5100 and it will take you to the Advance troubleshooting guide for your Desktop. Browse for the Diagnostics light as this will let you know what is wrong with your computer. Most likely this kind of issue pertains to a Memory or RAM issue which can sometimes be resolve by re-seating it. For further details of your computer, follow this link.
Aug 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Dec 21, 2009 | Dell Dimension E310 PC Desktop
Don't starts yellow light flasing
If the power button on the tower is flashing Amber, the fault is the power supply. Replace the power supply and they system should work.
If the power supply doesn't resolve then the 2nd most likely failure is the Front IO panel (Circuit card behind the power button)
Nov 22, 2009 | Dell XPS 400 PC Desktop
Dell computer won't come on...only get yellow light, no blue
If the Tower has a blue light, then it appears to be working, I'd check the cable connection to the video port on the tower and the INPUT Select Button of the Monitor (I've seen people change the input select to DVI when connected analog for example)
Sep 14, 2009 | Dell E176FP 17" LCD Monitor
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
120 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
