Lasonic Ghetto Blaster i931 Boombox
Problem for Lasonic Ghetto Blaster i931 Boombox
Problem with Lasonic i pod ghetto blaster
By hschott2413 on Jun 16, 2009
Last summer I purchased a Lasonic ghetto blaster and it worked fine while plugged in however when I tried to use it unplugged with batteries it did not work. I inquired to Lasonic and they told me that I needed to use all the same brand batteries. I just tried this the other day and it is still not working. I do not know if this is a common problem, or of where it can be repaired. Please let me know if you have any suggestions.
Hannah
Best Solution
posted on Jun 16, 2009
Helpful)
Skyassoc
Rank: Guru
Rating: 90%, 273 votes
Check to see if the batteries are in correctly or there is corrosion on the battery terminals. This may sound too easy but too many times i have seen it happen. Also check to see if there is a switch on the back near the battery lid or on the side of the unit for ac/batt power. If not there is a circuit problem with the unit. Most of the units like that have a year warrenty. If it is out of warrenty it probly would cost more to repair than to buy new.
Hope this helps,
Skyassoc
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 23, 2009
Not Rated)
jcbzy5_fixya
Rank: Apprentice
Rating: 0%, 0 votes
Happened to me, and a very common problem. on the top left of the battery compartment, there is a U shaped connector meant to hook up with the + battery on that side. it's too low, so the circuit doesnt complete. Use some aluminum foil or copper wire to make the U connect with that battery and it should work.
Was this helpful?
Yes
No
Popular Solutions for Lasonic Ghetto Blaster i931
Questions and Unsolved Problems for Lasonic Ghetto Blaster i931
Do you recommend Lasonic Ghetto Blaster i931 Boombox?
Answer
Answer
the cds dont work or open how do i fix that (evry time i press a cd it trys to work then stops and... (More)
Answer
How to dissassemble the Sirius Boombox SUBX1R
Answer
Boss DR880 back light comes on but no programs show. Have changed to a new power supply but no... (More)
Answer
rca cd, tape, radio. model rcd150. cd player spin very slowly.
Answer
radio does not work.Only thing that works is gfi plug.It is a bosch power box.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Lasonic Ghetto Blaster i931...:
Top Boombox Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Boombox Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
