Question about Jensen VM9510 Car DVD Player
CD Drive. [VM9311]
Jensen VM9311;
Well first off I bought this from a friend. The only problem with it is, is that the CD Drive inside if broke apearently, how do I fix this? How much would you think getting a professional to fix it is worth?
Re: CD Drive. [VM9311]
Well im kind of rookie but im looking on here and all of u have almost the same problem i did what i did is re built my drive by my self theres a strong spring in the back of the cd drive and it breaks a rodand a plastic harness i bought a broken jensesn vm9311 and looked at the insides and figured out what was wrong i was ****** that i spent all that money on mine and got anouther one for 20 that showed me what to do but hey i got a 400 dollar unit for 20 u know i fixed that one 2 if u want it we can talk about it just e mail me and ill either tell u what i did or u can send it to me and ill fix it 4 u u pay shiping both ways and we will talk more .................
Posted on Feb 04, 2012
Re: CD Drive. [VM9311] - Jensen VM9510 Car DVD Player Car Video Players
Im having the same problem
Posted on Sep 30, 2011
I get bad disk error message how can I fix this???
Posted on Sep 16, 2008
0 characters
3 Points
I have the VM9311 Jensen flip out screen and i want to know the parking break sequence to watch movies on it.
just ground it to any part of the car that has a good ground and you can watch movies wether you are driveing or not
Sep 27, 2009 | Jensen Car Video Players
daughter formated my hard drive by mistake got no recovery disc but reinstalled xp but got no sound drivers
Sep 21, 2009 | Jensen VM9510 Car DVD Player
Jensen vm9311 motorized screen wont close
no it's not your battery it is in the screen itself , the motorization is broken or damaged . You will need to get that repaired by either taking it to a repair shop in your local area that services jensen products or send it back to the company. If you choose to send it back to the company you will need to contact them first to get a return authorization number .
Audiovox/jensen 1-800-645-4994
Jul 04, 2009 | Car Video Players
I need to bypass brake for the jensens vm9311 so i can watch movies on drive
ok if you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 29, 2009 | Jensen VM9510 Car DVD Player
I just installed a VM9311 and when I turn the volume up it resets. Any suggestions?
check for loose wire in harness. Had same problem with 9412 that i have. Bought new harness at electronic express for 20 bucks. hope this helps
Jun 29, 2009 | Jensen VM9410 Car DVD Player
Jensen VM9311TS
try pressing the reset button.
Sep 07, 2008 | Jensen's VM9312 Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
How to get the secrat manu..
If you want that your screen works without braking system connect pink wire to ground (any metalic part)
Jun 04, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311 AM/FM/CD/DVD
you are mising to power on the factory amp.
Apr 25, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Oct 23, 2006 | Jensen VM9410 Car DVD Player
Jensen VM9510 Car DVD Player Logo
333 people viewed this question
Top Jensen Car Video Players Experts
Mike McWhinney
Are you a Jensen Car Video Player Expert? Answer questions, earn points and help others
