Question about Belkin (F5D9230-4) Wireless Router (F5D92304)
I have two questions 1. How do I secure my n1 Belkin router? 2. My new laptop (Lenovo Think Pad T500) seems to have "issues" with the router. Internet video feeds are choppy and stall. Access to email messages and web pages is slow. Any advice?
  • Belkin Master
  • 4,338 Answers
Here is a link on how to secure your router:
http://www.belkin.com/support/article/?lid=en&pid=F5D9230-4&aid=10177&scid=221
To correct the email and video issue, you may need to change the MTU settings:
Adjust your wireless router settings
  • Lower the MTU (Maximum Transmission Unit) from 1500 to 1492 or less (usually found on your router's main/ basic setup page)
  • Adjust the following advanced wireless settings:
    • Lower the beacon interval from 100 to 50
    • Lower the fragmentation threshold from 2346 to 2306
    • Lower the RTS threshold from 2347 to 2304
This is the address where you change MTU
192.168.2.1/wan_pppoe.html.
You can download the user manual from the previous link.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 16, 2009
My wireless doesnt work on my belkin n1 wireless router
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 24, 2010 | Belkin N1 Vision Wireless Router
Why belkin n1 wireless router security light is flashing ?
Aug 17, 2010 | Belkin N1 Wireless-N Wireless Router
Forgot my password have a new laptop and can not access my secured network without my password!
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span>1.Look at the back of the router and connect your laptop to any one of the 4 grey slots <br />2.In your laptop open IE and in address bar type <span style="font-weight: bold;">192.168.2.1</span><br />3.It will open a belkin router setup <br />4.In the belkin Router page select <span style="font-weight: bold;">SECURITY</span> in the left hand side <br />5.It will ask u a <span style="font-weight: bold;">login Pwd</span> . its <span style="font-weight: bold;">blank</span> Click <span style="font-weight: bold;">submit </span><br />6.In the next page u can see the Security Mode - If it is WEP - KEY 1 will be your PWD<br />7.If the PWD is WPA . The Pre shared key or password PSK will be the PWD . <span>Uncheck Obscure PSK to view the PWD .</span></span></span>
Aug 03, 2010 | Belkin N1 Vision Router
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
How do i install my new belkin systyem when ive
yes you can use it.
first connect your Belkin router to computer with lan cable .
Then access it wityh this link.
http://192.168.15.1
user name as "admin" and password as "admin"or
blank or
"password"
then configure your router as your old lynksys settings.then save settings and restart .
Aug 22, 2009 | Belkin N1 Vision Router
Belkin router is working with desk top computer. add laptop
It's asking for the security word that you entered into the router when you set up wireless security. You will need to enter both the wireless SSID, and the security key to make the system work.
Jan 24, 2009 | Belkin N1 Wireless-N Wireless Router
Trying to connect a Mybook 1Tb network drive to N1 Vision
Hi! I have an N1 Vision with similar problems. I have done some research and found that we are not alone with this issue! Two solutions are possible: 1) If yours is version 1 (1000) of the machine, Belkin recommends that it be swapped out for version 2, which apparently has firmware/hardware changes that fix this (unverified; it would seem to me that this would require a whole new DHCP approach) and 2) I've found that if you go through the process of unplugging the device for 2 minutes, replugging it and then refreshing the DHCP table, after between 1 and 5 iterations, the device should appear. I'd also advise you to shut down (for troubleshooting) the software firewall in the router (you'll still have the NAT firewall), that might eliminate a problem/conflict somewhere in your network!
Good luck and let me know if this helps!
Bob
Sep 23, 2008 | Belkin N1 Vision Router
Major issues
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now.
Hope this helps, and good luck!
Apr 16, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 Vision (Part # F5D8232-4) and VPN problem
I hade the same problem with mv Cisco VPN v5.0 and Belkin N1 router (F5D8231-4 v4...). I could only solve the problem with a new firmware (f5d8231-4 ww v4.00.18 at http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D8231uk4&aid=9419&scid=0 ). I think this is a general firmware issue at Belkin. Good luck.
Feb 27, 2008 | Belkin N1 Vision Router
Belkin (F5D9230-4) Wireless Router (F5D92304) Logo
298 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
