Question about Garden
The front drive wheels of my 21'' 6.75 craftsman will not engage
The bekt is in place and the pulley is turning but the shafts coming out of the small transmission are not turning.
  • slonez Jun 20, 2009
    The gear cost $6.99 at Sears. I have already fixed it. Thanks
    Scholar:
  • 81 Answers
Gogs (or gears) in the transmission box have worn down. It is probably cheaper to replace the whole transmission than it is to replace the gears.
Posted on Jun 19, 2009
The idler pulley assembly on cutting deck of a Craftsman 830 is not lining up straight with the the blade shaft pulley causing belts to be eaten. Do I need to tighten something? Replace something?
That pully has several washer with it. If they aren't there or out of place then the idler tensioner will run at an angle. Get the parts breakdown for it and check it to make sure all your parts are still there.
Oct 18, 2017 | Craftsman Garden
I have a Craftsman front wheel self propelled mower. The front wheels no longer turn either in self-propel or in manual push mode. What can be done to fix this?
Take a good look at the wheel assembly. Is it rusted on from being left exposed to the elements? Remove the cover for the self propelled mechanism. Is the drive belt intact? Try turning the small pulley.
Aug 20, 2016 | Craftsman Garden
Why is the forward engine pulley so hard to turn on my Craftsman 42" Model No. 247.288812 lawn tractor?
Are you talking about the Engagement pully? Item 24?
http://www.manualslib.com/manual/518759/Craftsman-247-288812.html?page=32#manual
If so, the reason it is hard to turn is because it is attached to the shaft of the engine and also has the pully for the wheel drive attached to the same shaft.
Jul 02, 2014 | Craftsman Garden
Craftsman lawn tractor will not move
There are a few things to look a. The belt, is it slipping or loose? Check and small idler pulleys from the drive belt to the engine. The large pully on the transmission is keyed to the shaft. If either the key is sheared or the shaft worn enough, the shaft will spin but not turn the pulley under load. Also note that the axles are keyed to the rear wheels. A sheared key there will cause it to not move also. You should see the axle turning freely inside the wheel if this is the case. Here is a parts diagram so you at lease have an idea of the areas to check.
Craftsman 917275810 diagram
Aug 22, 2012 | Craftsman Garden
I have a 2 yr old 8HP Craftsman snowblower. My small engine buddy picked it up in Nov to give it a tune up check the belts etc..I had been doing yearly maint on it but wanted to see how he busted it apart...
Are you trying to move the gear selector with the engine off? This is a friction wheel/disk transmission and the friction wheel usually will not move on the drive disk without the engine running.
If you have the bottom cover off, lift up on the drive wheel. (The rubber wheel. Lift it off the drive plate) It has tension on the plate using a spring. The gear shift lever should move then.
If it won't move check the sliding mechanism for the friction wheel and make sure it has a little grease on the shaft it slides on. Also check the cable and the pulleys the cable runs in. Sometimes the engagement cable (forward drive lever on the handle) falls off the pulleys. Sometimes these little pulleys will break.
These Craftsman snowblower transmissions are all basically the same. Here is a manual that shows the drive system.
http://www.managemylife.com/mmh/owner_manuals/23825/CRAFTSMAN-Snowthrower-Gas-L0909129?brand_name_search=craftsman+88970 Look at page 20, figure 22.
Let me know if you have any other questions or you need more clarification.
Jan 10, 2011 | Craftsman Garden
Craftsman model 917377411 front propelled drive not engaging
On your model I beleive these wheels are driven with small gears inside the inside diameter of the wheels. If the shaft is turning, then you probably have a gear problem. Remove a wheel and inspect both the wheel, and the small gear. They are prone to wear.I'd suggest replacing all four parts if worn.
Jul 18, 2010 | Craftsman Garden
Craftsman 6.0 lawnmower frontwheel drive won't engage .
Make sure the belt has not slipped off of the pulley on the engine output shaft just above the cutting blade. It is common with those type of drives for debris to make the belt hop off.
Jun 02, 2010 | Garden
Does Not drive, belt position not sure is correct, connected and tight. Engin runs and Blade turns just fine. Craftsman, 917.374511, Lawn Mower
"belt position not sure is correct," from your description above
The first thing to do would be make sure belt position is correct, connected and tight.
This system is quite simple, the belt goes in the pulley on the engine shaft and the pulley on the transaxle only, nothing else. Using a short piece of rope or anything else readily available, temporarily tie down the safety bail (handle) and engage the drive handle. Now check your belt, it should be fairly tight and you should not be able to turn the transaxle pulley without considerable effort, if it is easy to turn, replace the belt. Now release the safety bail (handle)
If the drive belt seems to be working okay as above, remove the front wheels and inspect the gear teeth in them. If the outer half of the teeth are worn down more than 1/2 the original size as compared to the inner half, replace the wheels.
While you have the wheels off, if you have a couple of blocks of wood or similar items, set one under each corner of the front of the main frame outside the arch of the blade and start the engine, engage the drive and observe the pinion gears, they should both be turning. If they are not, then you have a bad transaxle and are going to have to either replace it , use it strictly as a push mower, or replace the mower.
Oct 31, 2009 | Craftsman Garden
Craftsman rotary mower, p/n 917.374821 will not move sometimes.
It is quite possible that one or the other of your pinions (item 55 in parts manual) has gone bad in addition to the wheels. Start the mower, engage the drive and lift the back end just enough to clear the ground and see if both wheels turn. If only one wheel turns, attempt to stop it from turning by setting it on the ground at an angle, if the opposite wheel does not turn, you will need to inspect the pinions.
Oct 30, 2009 | Craftsman Garden
Rear wheel drive on mower does not engage
Its possible that the cable slipped does the pulley turn on top of trans.if so does the shaft turn if so then your gears on wheels need cleaned or replaced.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
