Question about SanDisk 4GB microSD High Capacity Memory Card
Cannot get pictures off of SDHC Card 4GB
I have a HP PSC-1610 printer that I use to download pictures from memory cards. When I put the SDHC card into it I get a "memory card error" message. I tried several times. Tnx Susan
    President:
  • 3,085 Answers
Could be it only supports SD cards up to 2gb but not SDHC.
Posted on Jun 17, 2009
When I insert my 4 gb memory card into my HP printer i get a "memory card error" (My 1 gb card works fine on the same printer).
Well, either the 4GB card contacts are grotty, or the HP PSC 2410 doesn't like your SDHC card somehow; though SDHC cards are supposed to be able to ratchet down to SD for compatibility and a driver update could possibly fix this, it hasn't yet. Use a card that isn't SDHC; this probably limits you to 2GB or 4GB (see the readme in the HP print driver setup package you use.)
Aug 06, 2011 | HP PSC 2410 All-In-One InkJet Printer
Hello I currently have a 2 GB memory card in my canon SD 1000, camera i want to upgrade to 4GB memory card, what is the best brand or type? Will 4GB SDHC memory card work with my canon camera? ...
The Canon SD1000 will work with SDHC cards, up to 32GB in size. Stick with any of the major brands and you won't have problems.
The HP 7350 will NOT work with SDHC cards, limited to SD cards 2GB and smaller.
Mar 26, 2011 | HP PhotoSmart 7350 InkJet Printer
The 2355 gives an error when I plug in a SD/SDHC Memory card, it won't read it.
Your HP all-in-one can read the following memory cards: CompactFlash (I, II), Memory Sticks, MultiMediaCard (MMC), Secure Digital, SmartMedia, and xD-Picture Card. Note: It will not read an SDHC.
Jan 21, 2011 | HP PSC 2355 All-In-One InkJet Printer
SanDisk 2GB microSD Memory Card not working
SaveMyUsb.com can recover data from most flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
I have a HP PSC 1610 All in one printer and I tried putting my media card in the SD slot and it tries to read the card but the red light flashes and says memory card error. HELP Please!
If using the Card Reader -
The HP all-in-one has detected an error with the memory card.
1. More than one memory card is inserted in the HP all-in-one.
2. An incompatible camera is connected through the camera port.
3. A memory card is inserted and a digital camera is connected at the same time.
Solution:
Remove and reinsert the memory card. It may be inserted incorrectly. If the problem continues, the memory card may be defective.
Remove one of the memory cards. Only one memory card can be used at a time.
Check the user guide that came with the camera to see if it supports PictBridge. If it does not, try using the cable that came with the camera to connect the camera to the USB port on the back of the HP all-in-one instead of to the HP all-in-one camera port. If the camera does support PictBridge, make sure the camera is set to PictBridge mode. See the user guide that came with the camera for instructions on how to do this.
Remove the memory card or disconnect the camera. Only one can be used at a time.
You might try the following - Reformat the memory card in the camera or format the memory card in a Windows XP computer by selecting the FAT format.
Hope this helps!
May 01, 2010 | HP PSC 1610 All-In-One InkJet Printer
Card reader not working?!
Have you tried another memory card?
Some devices can read SD but not SDHC. If your memory card is 1 or 2 gig, it's SD, if it's larger, it's SDHC which is not backwards compatible with SD.
Based on the age of the PSC 1350, I would bet it's a SD-only device.
Nov 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
Remove memory card HP PSC 1610 All-in-One
Usually the memory cards fit in with a push. But if you push them further in one more time, they are ejected. Do let me know if that worked or not. Otherwise I will search for some other step.
May 14, 2009 | HP PSC 1610 All-In-One InkJet Printer
Memory card error
HP printers only reads only 1 gb memory cards.
For further information.
Click on the web link given below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265347&cc=us&lc=en&dlc=en&product=390315
Have a great day!
Mar 23, 2008 | HP PSC 1610 All-In-One InkJet Printer
SanDisk 4GB microSD High Capacity Memory Card Logo
1,378 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
