Question about Sony Walkman SRF-M37V AM/FM/Weather/TV Radio
No more TV on Sony TV/weather/fm/am walkman srf-m37v.
Since the TV station swich over I have not been able to get the TV channels on my Sony TV/weather/fm/am walkman srf-m37v. Do I need to do something?
Kim
    President:
  • 2,992 Answers
There's nothing you can do. With the switch to digital broadcasting, the sound isn't on the same frequencies it used to be so this radio can't pick it up. Right now, nobody's offering a digital receiver for the sound. All your radio is good for now is the regular radio and weather broadcasts.
Posted on Jun 17, 2009
I need a user manual for a Sony walkman, model SRF-M80V.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=SRFM80V
Nov 18, 2010 | Sony Walkman SRF-M80V AM/FM/Weather/TV...
After battery ran low, now radio will not power up with power button.
Make sure you don't have the HOLD button engaged. This button is what keeps your station buttons, power, etc., from accidently switching when you bump it.
This button is found on the top right hand side of the radio if you are looking down on the radio with the clock display facing you.
If the button is showing the red painted mark, you have the HOLD button engaged. Switch it off, and then press the Power button to turn on the radio.
Sep 23, 2010 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
I believe I need to replace the internal battery for my sony walkman srfm37v as I've had it for a long time and even if I install a brand new triple A, the hold key won't go off (even by sliding the switch...
There is no internal battery on the Sony SRV-M37V. Presets are held in non-volatile RAM and don't need power to maintain the settings.
Your problem is that the hold switch is not disengaging. Either the contact below the switch has gotten gummed up and won't release, or perhaps the switch is broken.
You can try spraying a tiny (very tiny) amount of Contact Cleaner (available at Radio Shack for less than $5) into the switch. Or disassemble the unit to see why the switch isn't making contact like it should. Hope that helps!
Jun 30, 2010 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
The left side sound is out I thought it was the headphones or earbuds but I even bought new ones and the same problem.
This can be a failure of the connection jack inside the unit or the electronics that supply the signal to the headphone connection. Connectors like this can be purchased at radio shack. The unit will need to be opened up by removing the screws in the back to see if the jack is loose or damaged. You can then plan your next move. be it re solder the existing connector or replace the connector entirely. if you are lacking solder skills locate someone who can help or take the unit to a shop.
May 09, 2010 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
I have a Sony Walkman TV/Weather/FM/AM SRF-M37V. I need to know
The radio won't get TV sound anymore after the switch. And no, nobody is selling a digital receiver for the TV sound yet. All this radio is good for now is regular broadcasting and the weather band.
Jun 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
No sound
If you are getting AM sound, but not FM, its because the headphones you are using are shielded for interference. This shielding is what is causing you not to be able to pickup FM, as the headphone wires are what is used as an FM antenna for the unit. Try using a CHEAPER set of headphones (Yes, I said cheaper). Cheaper headphones usually don't have the shielding. Usually these types of headphones have both wires for the headphones bound together as one wire.
Apr 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Sony Walkman SRF-M37V AM/FM/Weather/TV Radio Logo
395 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
