Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Usb 8 gb doesn't show on my pc, light flickers and stays on
In My Computer, I can only see U3 System, the flash drive has no letter, the light goes on and off, then stays on but have no access to the drive.
  • mmurphyt Jun 17, 2009
    Thanks for the advice! My laptop didn't provide enough power that the desktop I tested on did and it worked!
  • 71 Answers
Probably the flash drive is not getting enough power from the computer. Try to connect the flash drive to the USB port located at the back of the tower.
Posted on Jun 17, 2009
Noticed that the light on the flash drive would fade in/fade out. Inserted the drive into a desktop computer rather than on my laptop and it worked just fine. Insufficient power was the culprit. Thanks for the help!
What can I do
I have an Acer c720 chromebook and there is a message that says that my chrome os is missing or damaged... and that I will need a usb flash drive or a sd card. So I got an 8 gb usb cruzer blade flash drive stick then it says it doesn,t work with my chrome os and then goes back to the first page and doesn,t let me get on anything else. What can I do? Plz help
Jan 07, 2014 | Dell Dimension 2400 PC Desktop
My pc doesn't show sandisk cruzer blade 4 gb pen drive whereas it shows others
Sometimes, windwos OS, give same drive letter to different devices, and when you connect both, one is not showing. So, you need to go in to Disk Manage (right clic on "My PC", clic on Manage") and verify if you can assign a different driver letter to your pen drive.
Oct 01, 2012 | SanDisk SDCZ50-004G-P95 4GB Cruzer Blade...
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Can i install u3 smart launchpad on my kingston data traveller G2
well U3 system software is pre-loaded to USB devices by the manufacturer and requires special flash drive controller line and thus it is not possible to install u3 by user.
Good Luck.
Jan 06, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Lost instructions need to know how to download pictures to cruzer micro
USER MANUAL LINK
Copying to or from a USB device is the same as copying to or from any standard disk device.
1. Click on your desired file to select it.
NOTE: You can select multiple files by holding down the Ctrl while left click on the desired files. Or you can select all files by holding down Ctrl and press A.
2. On your keyboard, hold down the Ctrl key and press C.
3. Navigate to the desired folder destination.
4. Hold down the Ctrl key and press V.
U3 smart drive is a USB flash drive that allows you to install and run U3 smart applications from the U3 smart drive itself. When you use a drive in this manner, you can take your applications with you and run them on any Windows 2000 or XP computer.
Not only can you use the U3 smart drive for carrying your files but you can also carry your applications with your personalized settings with you as well. There is an application that is included on every U3 smart drive called the U3 Launchpad and it is your console for managing the applications that are installed on your U3 smart drive. The U3 Launchpad also provides utilities that let you customize your U3 smart drive your way.
More on U3:
Under the hood, a U3 smart drive is an advanced USB flash drive with special features that allow the U3 smart drive to take on multiple personalities depending on how it has been configured. The default configuration is composed of two drive letters or domains. One of the drive letters is a removable mass storage domain just like any other USB flash drive. The other drive letter or domain emulates a closed CD-R CD disc in a CD drive and contains the U3 system files that makeup the U3 Launchpad. When you connect the U3 smart drive to your PC, you will see two new drive letters after the Windows OS has fully set up the drive.
You will see the emulated CD-R drive which usually is indicated in file explorer by a U3 logo and another drive letter that is the mass storage domain. The mass storage drive letter will have a label with a name like "My U3 Drive" or some other manufacturer specific label. Newer versions of the U3 Launchpad lets you rename the drive letter label using the Status and Settings dialog. Older U3 Launchpads can be renamed by right clicking on its drive letter label in file explorer and selecting rename.
The drive letters assigned to the two drive domains by the Windows operating system can be any available letter but typically are between F: and Z:. The two letters may or may not be sequential and the mass storage drive letter may be before the CD-R drive letter. You do need to see both drive letters appear in order for the U3 Launchpad to run.
Dec 11, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Scandisk cruzer - system files deleted
Hi ,
You can Uninstall the U3 system , link to uninstaller can be found at : http://www.u3.com/support/default.aspx#CQ3
once you uninstall it you can go back and reinstall the U3 system from the same website.
Jan 29, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
U3 Flash Drives - What Are They and How to Remove U3 Software if Desired
U3 Smart Drives are regular USB flash drives with a twist. Programs can be installed on them and the data from those programs will travel with you. In other words, U3 Drives are computers on a stick. Although the technology is relatively new (the company started in January 2005), there is a wide variety of programs that can be used on these supercharged USB drives.
One of the most important advantages of using a U3 enabled flash drive is the ability to take your documents, photos, email, address book, favorites, webpage logins, and more with you wherever you go.
Of course you can backup all these files on a normal USB flash drive or other removable device, but the advantage of using a U3 drive is the programs along with the data are on the USB drive. This means you'll be able to work on a report, view photos, look up an email address, and more simply by plugging the device into a computer and pulling it up. You dont necessarily have to take a laptop with you anymore to get your work done.
You can't make a "normal" USB flash drive into a U3 enabled drive. The U3 system software is pre-loaded on the drives and cannot be added to a normal drive. When a U3 drive is plugged into a computer, it creates two drives. One is a CD drive with the system software on it and the other is a removable drive that you can use to store information.
Oct 18, 2008 | Computers & Internet
Lost space in my Sandisk Cruzer
I had the same problem. Just go to Sandisk's website and download the latest U3 removal tool, run it and it will format it back to 7.5 GB.
Oct 14, 2008 | Electronics - Others
My U3 Smart SanDisk Cruzer Micro 2.0GB USB Drive Not Recognized
We can fix it -- and recover the data (provided it is recoverable -- which it generally is). If we don't get your data back, we ship the drive back to you and you pay nothing. We've been recovering data for over 16 years and are successful about 85% of the time.
Craftsman Computer Services, Cudahy, Wisconsin
Aug 02, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
417 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Alun Cox
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
