Question about MTX Thunder 6500D Car Audio Amplifier
I have the thunder6500D installed it work for
I have the thunder6500D installed upside down it work for about 4 days then stop working, i have power in the unit no fuses have blown up and sometimes the sound comes back again on its own. the rca wires are new and so all the wires i have used and wend i tap over the unit the sound comes back too by having the amplifier upsidedown i'm creating a problem? what can i do?
    Problem Solver:
  • 11 Answers
Hi, It sounds like your amps thermal shutoff is tripping since when the amp is upside down it can't cool as well as right side up. If you absolutely must mount it the way you have, I would recommend getting yourself a small fan, like a computer fan and mount it to blow on amp when system is on. They draw very little power, so you can just wire to your car's switched power source...but be careful to wire it to amps ground due to noise that can sometimes happen when you ground things at different locations around vehicle. Google "amp fans" or "computer fans" and you should find a good spot to get one. Make sure you get a 12v unit. Let me know if this helps! THanks
Posted on Jun 17, 2009
All the components are working properly but i am not getting anyh display on my monitor i replaced every thing and checked my monitor is working ram is working cpu fan is working power supply is ok smps is...
1- evolve the battery.
2- install it again but upside down.
3- turn on the PC.
4- wait 15 seconds.
5- turn the PC off.
6- install the battery correctly and enjoy. please rate.
Jan 17, 2011 | Mercury P4VM800M7 Motherboard
Asus P5OIJ web cam views upside down. the web cam on skype works great, but the person iam communicating with views me upside down. how can i fix this.
asus P5OIJ web cam views upside down. the web cam on skype works great, but the person iam communicating with views me upside down. how can i fix this.
Jan 03, 2011 | ASUS Computers & Internet
My 4 slice Dualit toaster stopped working! Repair?
I had an issue where it wouldn't stay down, or heat even if I held it down. No power at all.
Firstly unplug it.
To take it apart, turn it upside down. You have to get the 4 security bolts undone which are underneath (Mine look like they have six holes around them).
Also, you need to unscrew the bobble by hand which you use to push the toast down. You can then pull the cover off, from the back first. The timer dial is connected to the cover, but I didn't disconnect this.
Note: You don't need to undo the bolts inside the toaster. (They only hold the metal base to the plastic base), the 4 torx screws holding the side panel on, or the 4 twisted pieces of metal which hold the toaster internals to the base.
Inside, there are 4 prongs which are pushed together when you push the toast down. On further inspection, I found the main blue power cable had become corroded, and had melted and become disconnected. So simply unscrewed the 2 screws hold this section on,(simply for easier access) and resoldered the blue cable back onto the correct prong.
And now it works again!
May 24, 2010 | Dualit CTS4E 4-Slice Toaster
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
Hoover ensign 330 clother dryer -upside down install??
No it is not ok to install it upside down the bearing are not designed to work inverted
Jan 26, 2010 | Hoover Dryers
Usb ports on motherboard are not working. They do not seem to have any power. None of the ports work. Not even the front ones. I've tried reinstalling the drivers, installing different drivers, I've...
If the usb ports don't seam to have power, I suspect that at some time something was plugged into one of the ports, either at an angle or upside down, shorting the +5 vdc supply. Usually the supply voltage is fed to the ports thru a "zero ohm resistor", basically a fuse that blows protecting the power supply. You may be able to find and replace it but much easier is to install a 4 port usb pci card. They're cheap and you can go to 2.0.
Jan 13, 2010 | EliteGroup P4M800-M7 Motherboard
Sceptre 40" 1080P LCD HDTV Display Upside Down
Sceptre X37sv-Naga 37 in. LCD Television
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Beeping or stuck keys?
turn it upside down and pat it a little or use some air from a canwith it upside down
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 23, 2007 | Sony VAIO VGN-FS840/W Notebook
MTX Thunder 6500D Car Audio Amplifier Logo
134 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
