Question about HP A4331D 20" CRT Monitor
Monitor Speakers play start up sound, but no audio for video clips
  • 38 Answers
Check the setting of the sound > volume.... Check if he volume is mute....
Posted on Aug 03, 2009
Sound aoc l22w861 lcd tv pc monitor
It may be the game options or the system options may be set to something else than speakers
Mar 20, 2014 | Sony Playstation 3 (PS3) Console
I want to make my monitor speakers play sound
Make sure that you have the cable plugged into the monitor and going to the computer if there is one. Some older model monitors operated that way.
Click Start/Control Panel and check your Audio/Sound properties to make sure the drivers are ok. Look for either sound or audio or device manager under the control panel.
Does the sound work for external speakers? Does the sound work for a headphone? Did the computer and monitor come together when you purchased it?
Mar 24, 2012 | HP Computers & Internet
I bought a HP 2311x23 monitor to run off of my Hp turion2 laptop. I cannot get audio to run on the big screen when I attempt to watch a video. No problems on the laptop screen.
Hello - From what you've written I would assume that you have connected your notebook to your new monitor with an HDMI cable. You have the right idea. The problem is, yes HDMI does carry both video and audio, but your new monitor doesn't have any way to output the sound...no speakers.
When your laptop connected to the external monitor it recognized the HDMI and assumed the device was sound capable. You need to go to Start > Control Panel > Sound and setup the sound to go through your notebooks speakers like it normally does and not try to send sound to the monitor.
After the change you'll view the video on your new monitor and the sound will be output by your laptop speakers like always.
Thanks for using Fix Ya and enjoy your new LED display.
Mikeywaf
Mar 14, 2011 | Office Equipment & Supplies
Monitor speakers cannot function despite connecting the audio cable and checking the volume
nienqajm, Tell me if you hear anything if you connect a set of "ear buds" to the "mint" green color audio output connector "jack" on the pc!! Play a video clip with audio at YOUTUBE and you should hear something if audio not on mute. 12fixlouie
Oct 25, 2010 | NEC MultiSync LCD1525M (Black) 15" LCD...
No sound when playing video
hi bearly,
this may be due to codec issues, there are special video and audio codecs needed to give sound to webbased films and videos.
try downloding k-lite codec pack or xp-codec install, reboot and try to access youtube again!
good luck
Sep 07, 2009 | HP w1907 LCD Monitor
Hannspree HF259H Audio (sound) Problem
I connected an audio cable from my sound card to the audio unput on the monitor and the monitor plays everything as well as my other speakers connected to my sound card. I have a Diamond multimedia sound card (7.1 setting) By the way, the monitor speakers sound "tinny" if the volume setting on the monitor is too high.
Dec 23, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Problem with DELL 2408WFP
I have similar problem.  I'm using the HDMI connection from my PC to the monitor and when I connect my audio out from the monitor I get hissing and popping sounds along with the audio.  It sounds pathetic, I also hear the music and audio along with the hissing and popping.
If I connect the audio to the back of the PC the sound is crystal Clear.  I am using Vista 64 bit with NVIDIA GeForce 8600 GT video card.  Trying  to Google to see if others are are seeing the same problem.  I just got my monitor on Oct 6.
Sep 30, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
External speakers do not play
It is not an issue with the speakers or the sound card as you get sound in media player and also while playing cd's.
It could be the volume settings on the player tht the websites use to play the audio or the video,
Jan 30, 2008 | Neovo E-19A 19" LCD Monitor
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
HP A4331D 20" CRT Monitor Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
