Question about Toshiba 50HP66 50 in. Plasma Television
I have a black rectangle covering the center of the screen from top to bottom. How do I get rid of it? I tried the menu for Closed Captioning but it did not seem to work.
    Problem Solver:
  • 5 Answers
Try turning off the closed caption and text also check v chip, if you have a channel or channels blocked it could cause a black rectangle to pull up on the screen, if that doesn't work try resetting the unit to factory settings
Posted on Jul 06, 2009
I have a blank black rectangle on my screen. When I hit the menu button I can see the full image in the background but when I exit the menu the rectangle comes back. How do I get rid of it???
Tv still have Close Captioning functions is on.Tries tv remote button like CC turn off all CC1,2,3 to all off.Or goto tv menu goto Close Captioning turn off all CC1,2,3 or Text 1,2,3 to all off.Should stop the rectangle square appearing.
Mar 02, 2011 | JVC AV-27020 TV
There is a large black rectangle in the middle of the screen. It goes away for a second when I press the EXIT button on the remote and for about 4 seconds when I press the RECALL button on the remote. ...
This is a text box. This can be turned off under the closed captioning. There should be a cc button on your remote or the closed captioning features can be accessed from your television's menu. Turn closed captioning completely off to get rid of these text boxes.
Keep in mind that closed captioning can also come from your cable box or satellite receiver as well.
Sep 28, 2010 | Toshiba 32A33 32" TV
Small black rectangle in upper left corner of toshiba 52hm85 dlp
Sounds like it is closed captioning coming up. I would go in and verify both your TV's and the Cable/Satellites closed captioning is off.
Mar 06, 2010 | Televison & Video
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
Black Rectangle on Bottom of Screen
It is your Closed Captioning malfunctioning. You can try and access the menu and turn the CC off but more times than not it is a malfunction that is unfixable.
Please remember to rate this solution.
Feb 13, 2009 | Curtis-Mathis CM27101S TV
Black box in middle of screen
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Vizio 42" LCD - Random appearance of small black rectangles
I would check and see if you have the text option on under your closed captioning. With the new digital transition the signal for text captioning has been getting messed up during broadcast here lately. If it is on i would just shut it off or go to regular closed captioning.
Nov 02, 2008 | Vizio GV42L 42 in. LCD Television
Older model sharp tv G1018CESA large solid black rectangle on top of picture dont know how to get rid of? if i change channels can see full picture but rectangle pops up in seconds
Go into the menu and turn off closed captioning. You have accidentally turned it on to text or cc1 or cc2, but that is positively what is wrong. Good Luck! Please rate this solution!! Thank you,
barneyluc
Oct 06, 2008 | Televison & Video
Black Rectangle on lower half of TV screen.
Turn off the closed captioning feature. If a channel or program doesn't provide the captioning, all you get is the black box. Just find the menu page for that and change the setup.
Jan 10, 2008 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Black rectangle blocking view
SOUNDS LIKE U HAVE THE CLOSED CAPTIONING ON, CHECK IN YOUR MENU AND TURN OFF
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Toshiba 50HP66 50 in. Plasma Television Logo
171 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
