Question about Denon AVR-1507 Receiver
Where do I connect passice subwoofer
How do I connect the subwoofer to the dennon 1507. Mu subwoofer doed not have built in amplifier
  • 979 Answers
How many terminals does your s woofer have?
accordianman
Posted on Nov 01, 2007
Kenwood radio rca sub outs. How do I hook up a sub and will it work without an amp
You can't, unless it's a sub with a built-in amplifier. A subwoofer pre-amp output is meant to be connected to an amplifier, not directly to a subwoofer. You must have an amp to drive a sub.
Aug 27, 2015 | Kenwood Car Audio & Video
Is there any way you can connect two subwwofers to this receiver?
Certainly... the easiest way is to purchase an RCA Y adapter to split the pre-out subwoofer connection to both subs.
Here's a link to what you need: (Best Buy)
http://tinyurl.com/ctp44j
This will not, however, give you a discrete left and right sub. You'll need a receiver with 7.2 capability to do that.
Make sure the phase is set the same on both subwoofers, or they'll cancel each other out and you'll end up with less bass than you had before with one sub.
If this answers your question, would you rate it for me?
Apr 20, 2009 | Denon AVR-1507 Receiver
Alpine MRV-1507 "low Voltage"
If it indicates that you have an open shield ground, read through the following page. It will show you how to test the shield ground connection of your head unit..
Temporary RCA Shield Repair
Aug 14, 2008 | Alpine MRV-1507 Car Audio Amplifier
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Jul 07, 2008 | Alpine MRV-1507 Car Audio Amplifier
Hi, im jason!
Any car Amp rated around 200watts, 4ohms... (bridged)
If you don`t stick to these ratings you can damage speaker...
Post From Tricky...
Jun 16, 2008 | Alpine MRV-1507 Car Audio Amplifier
Sonamp Set up
Tape out from dennon to tape in on sonamp then select source from dennon.
GOD LUCK
BIGRED
Apr 01, 2008 | Sonance Sonamp 260 MKII 2-Channel...
Help please
Check your power cable, for bad connections.
Make sure voltage dont drop below 10.8v.
Nov 30, 2007 | Kicker IX404 Car Audio Amplifier
Subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
Sep 14, 2007 | Polk Audio CSi40 Center Speaker
Connecting a PASSIVE subwoofer to the denon AVR-1507
Yes on B Connect Left+ Right+ Equals Mono And Turn on B Side with A
Jul 01, 2007 | Denon AVR-1507 Receiver
Denon AVR-1507 Receiver Logo
119 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
