Question about Panasonic KX-TG6700 Phone
Flashing lite on all handsets can't be shut off;
Flashing lite on all handsets can't be shut off; no messags all fully charged
  • 43 Answers
Yes you can go to settings menu and can switch off the backlight, this will save your battery power
Posted on Jun 16, 2009
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
DECT 1480-4 Uniden Corless phone- how do you get rid of red LED lite ?
Do you mean the status light on the handset or the one on the base? The status light on the base will be on if the answering system is on. The handset status light will be on but steady when the handset is on the charger. (It's a battery charging indicator in that case; take the handset off the charger to stop the charging system. It provides a trickle charge to offset the battery discharging over time) The light blinks to indicate new messages are available on the answering system. Press the Play button on the base or the Messages/Mute button on the handset to play new messages.
Uniden offers the manuals for many of their phones on their support site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The direct link to the manual for the DECT-1480 is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf .
I hope this helps.
Dec 02, 2011 | Lands Phones
My problem is that every time I turn on my ds lite the white light flashes and then it shuts off and it's fully charged.
Hi the solution to your problem is
A failed top screen the ribbon had gone
The green light comes on screen flashes an then goes off
I repair nintendo ds lites in the uk
So can sort you out for a reasonable price
Apr 23, 2011 | Nintendo DS Lite Console
My mobile display was problem. i want to touch my menu icons its not working. how to solve this problem?
You need to update your handset firmware-rokr-e6. to update your handset..
  • First you need to install your motorola phone tools ....
  • Go to the option live update.......
  • Download the software named [Motorola_Software_Update]
  • Backup your contacts and open your SIM&SDcard....
  • Then Using Motorola_Software_Update go through the stapes..
If thats not working
You have to Flash your firmware-rokr-e6.........
  1. Install the Motorola_Software_Update.....
  2. Download the software named RSD Lite........
  3. Download any firmware-rokr-e6 as you like.........
  4. Backup your contacts and open your SIM & SDcard....
  5. Turn off your Motorola ROKR E6 Smartphone when its battery will be fully charged
  6. Tap and hold Your Power +Camera key for 3-6 seconds when it is connected to your pc.
  7. At last brows the firmware-rokr-e6 and press the button start on RSD Lite.......
  8. Do not dis connect your phone from your pc...
If the RSD Lite can not show Device the flashing can not be finish....
You have to wait for finish the Flash method
Dec 01, 2010 | Motorola Mobility ROKR E6 Smartphone
My DS Lite shuts off after a fraction of a second of being on. the bottom screen flashes but the top screen stays blank. I replaced the battery and it still does this. I fully charged the battery and it...
It's a problem with one of the LCDs. The DS Lite will do a power on self test -- if one of the screens has a problem, it will flash and turn itself off to avoid damaging the unit further.
Sep 21, 2010 | Video Game Consoles & Games
Nintendo ds lite power cutting out
I need a proper diagnosis. Does the top screen flash?
email pcs_cheltenham@ymail.com I may be able to help
Jul 03, 2008 | Video Game Consoles & Games
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Philips SE 435 Handset beeping intermittently
I had this problem, solved it by going to the advanced settings menu and resetting the handset. I guess the handset got out of sync with the base station after I deleted messages... once reset it was fine.
Jan 27, 2008 | Lands Phones
Panasonic KX-TG6700 Phone Logo
79 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
