Janome Magnolia 7330 Sewing Machine Logo
Judith Phillips Posted on Apr 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E1 came up and it froze....I have taken it apart and cleaned it, and it is still frozen...I believe it is the fuses..where can I purchase them, and approximately what is the cost?
Debbie
Level 3:
  • Janome Master 1,860 Answers
  • Posted on May 01, 2014
Debbie
Janome Master
Level 3:
Answers
1860
Questions
0
Helped
384520
Points
9030
You'll have to contact a Janome dealer & ask about the fuses
Testimonial: "I have done this and it works for a few seconds and blows them again...could it be in the board?"
  • Debbie May 02, 2014
    yes, it could be the board, or it could be a battery connection problem, or a wiring problem, it would be a good idea to have it checked.
My Kenmore 385.19923 sewing machine is showing an E1 error. what does this mean/
All the Error codes and the fixes below.
https://www.searspartsdirect.com/diy/error-codes/sewing-machine-repair/1234596/kenmore-385-model-sewing-machine/0582
E1 Error
Zigzag motor error
Check/Repair
The E1 Error code appears when the needle bar is up and the sewing machine can't prepare the zigzag motor to start. Unplug the sewing machine and check the wiring connections on the zigzag motor and circuit board A. Replace the fuse on circuit board A if the fuse is blown. Replace circuit board A if it has a burned spot. Replace the zigzag motor if the fuse blows and circuit board A is okay. Possible parts
Fuse, circuit board A, zigzag motor
What To Do With E1 Error On Kenmore Sewing Machine?
Wayne Arthur Gallery https://www.waynearthurgallery.com > what-to-do-wit...
Sep 23, 2022 - Check the wiring connections on the zigzag motor and circuit board A. If there's a blown fuse, replace it. Disconnect the sewing machine to ...
Missing: 385.19233 ‎' Show results with: 385.19233
I have a new Kenmore sewing machine..I am receiving an ...
JustAnswer https://www.justanswer.com > Appliance Repair
Jul 11, 2011 - The E1 error code indicates that a fuse is blown on the control board. The first image below shows the fuse that corresponds to the E1 error ...
1 answer · Top answer: Hello I'm Larry and thank you for using this service. I'll be helping you with your ...
2answers
What does an E1 Error mean on my Kenmore sewing machine
The E1 error code indicates that a fuse is blown on the control board. The first image below shows the fuse that corresponds to the E1 error code. NOTE: Be sure to unplug the sewing machine before you access any internal parts.Jun 10, 2008
It froze up and will not turn manually or with power
Please advise the brand and model number of your machine.
If it is a mechanical machine (not electronic/computerized), it most likely needs a good cleaning and oiling. If not oiled regularly, the old oil dries and turns to gum (varnish) and the metal parts begin sticking together until they are completely frozen and the motor is no longer strong enough to compensate.
Frozen motor
well, you don't. Germany should have sewing machine repair people. Call around.
E1-Error message is apparently the fuse were is
The E1 error message. This is due to the fuse having to be switched from the 2.5 amp to a 3.5 amp. they did not recall the machine because of the low cost $2.99.
The Fuse is Located on the Board itself.
I guess the Part Number for your model is 000182177.
You could Purchase that from :-
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=000182177&productGroupId=0020&supplierId=385&pathTaken=&filterPart=&pop=flush
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Pfaff 2020 Foot Pedal--taken apart; need help putting back tog.
Are you able to post a picture of what pieces you have? The contact board may not be pressed down all the way or the contact itself may be bent. You should be able to purchase both pieces if needed from a pfaff dealer.
1helpful
2answers
E1, E2 error messages after needle breaks. Cleaned everything as good as possible, still getting message. I have a Kenmore Model 385.19233
Theirs a problem with the fuse on those machines. The e1 indicates that a fuse has been blown. check out the link for more details.
http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
