Interest rate is 16% per annum. The first deposit is R1 000 and every subsequent deposit will be increased each time by 9%. How do I calculate the Resultant Rate?
SOURCE: Viking V714 calculator tax rate change
1. Press C button
2. Press 1 then 5 button for the 15% VAT rate - 15 is shown on screen
3 Press SET Button
4. Press TAX+ button
5 Press = Button - 15.00 is shown on screen
All is done, check by doing:
C
100
TAX+
answer will be 115.00
Press TAX+ again- answer is 15.00
SOURCE: Set Tax Rate
First clear all w/ ON/AC.
Enter the tax rate desired eg. 7 for 7% (can you tell I'm in PA)
Press RATE then TAX+
Press C/CE.
The next time you use TAX+ it will calculate and add the value that you set.
Do the same for TAX-, you can use a different value for each as they are separate memories.
SOURCE: change the tax rate on calculator on MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
SOURCE: I need to calculate NPV
Did you take into account that you have beginning of the year payements? Your calculator probably treats it as an end-of-the-year payment? Did you try treating the first payement as an initial cash flow (should be available as an option in your calculator input) and the treat the three remaining years as end of the year payements at your 9% rate. It should do it.
SOURCE: how to change tax rate on MS-8TV calculator
Press AC first, then hold down the RATE SET % button for 2 seconds, then input the rate and press RATE SET % button again
And you should be away :-)
